Go to Post You really don't want to mess with an engineer. - ChrisH [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 15-02-2011, 01:19
BrandonG's Avatar
BrandonG BrandonG is offline
IRC Junkie
FRC #2865 (Roboteknix)
BrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of light
Problems connecting to Jaguars from cRIO
We are having a problem where we can use BDC-COMM to access and control jaguars, but when using the black jaguars in LabVIEW as CAN, and using the appropriate serial adapter and cables (RJ12 6p6c), they appear as if to be stuck in pwm mode (flashing lights, as opposed to the solid when they are in CAN mode). We can read from them with LabVIEW, but not write: e.g. set values for motion.
Black Jag with FW V92
cRIO FW V25
LabView 8.6.1f3 update 3.1
We have tried the jaguars in a single and daisy chain configuration with the same problem; controllable via BDC-COMM but not LabVIEW.
www.roboteknix.com
Originally Posted by A bum in Atlanta
if you was my sister I'd mug you
If anyone uses IRC, pm me and let me know what networks, I have never heard of anyone in FRC using IRC besides me O_o
Unread 15-02-2011, 20:24
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Problems connecting to Jaguars from cRIO
Have you set the plugin on the cRIO?
Have you enabled the robot (using the Driver Station)?
-- Marshal Horn
Unread 15-02-2011, 21:07
KillerGardevoir KillerGardevoir is offline
KillerGardevoir is an unknown quantity at this point
(I'm a mentor for 2865 who initially discovered and attempted to diagnose the issue) The plugin is set, we are using the firmware utility that uses "net console" (built 12.16.2010 if memory serves, acquired from the PDF describing how to get CAN working) which we enable and select the Black Jaguar plugin. In addition we have tried the latest public (v28) firmware for the cRIO, I haven't been able to locate an older version, but I imagine I would get a similar result.
The robot is not enabled, nor is the driver station in the loop, but it also does not check any state, or for that matter the presence of a driver station. All it does is attempt to set the value of the jaguars, which it simply fails quietly at.
Note we can read just fine, so we know the bus is working, and for all intensive purposes should function just fine. We have tried 2 different cRIO's so unless there is an issue with the firmware, the firmware utility, the black jaguar plugin* or somehow two cRIO's have the exact same malfunction; it must be an issue in the code which I am unable to identify. I have attached the code we are using (note: 11 is the valid device number as we do get feedback from that jaguar)
*This is who, if not the code, is probably causing the issue, as it is the only commonality between all the tests.
Unread 15-02-2011, 21:32
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
If it is not connected via the Driver Station, you cannot set the output of the Jaguar. This is one of the things that is specific to the FIRST Jaguar firmware.
-- Marshal Horn
Unread 16-02-2011, 11:13
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Agreed with ^^^^
If the robot is not enabled the cRio will not allow output period.
So enable your robot and report back!
Unread 16-02-2011, 14:18
BrandonG's Avatar
IRC Junkie
Thanks all, that solved it
www.roboteknix.com
Unread 16-02-2011, 15:53
This seems like something that should be listed in the documentation somewhere, under a section like "Things you need to know about the RobotDrive Algorithms" or something to that extent.
