#9
Re: Problems with Deploying code
Have you tried reimaging the CRIO. If you're using CAN try formatting it without any of the Can Drivers, and then go back in and put the CAN drivers on without reformatting. Also use netConsole to check that you aren't getting any run-time errors.
