Go to Post Holy Underwriters Laboratories Industrial Safety Awards Batman! - AndyB [more]
Unread 14-02-2011, 19:40
SGS's Avatar
SGS SGS is offline
AKA: Christine Gebara
FRC #3103 (Iron Plaid)
SGS is a glorious beacon of lightSGS is a glorious beacon of lightSGS is a glorious beacon of lightSGS is a glorious beacon of lightSGS is a glorious beacon of light
ViAir Air compressor needed
Our team is trying to get a new, lighter air compressor. We were looking at the ViAir 90c compressor, but it seems to be on back order EVERYWHERE. Does anyone know of a comparable compressor that is just as light (about 2.5 lbs or less)?
Unread 14-02-2011, 20:17
Re: ViAir Air compressor needed
The ViAir 92c and 95c.
Unread 14-02-2011, 22:30
bstrong1218's Avatar
bstrong1218 bstrong1218 is offline
Brandon
AKA: Brandon
FRC #3344 (Robocopz)
bstrong1218 is an unknown quantity at this point
We got the 95C. Pretty sure the only difference is in the mounting bracket. We hope to fire it up for testing tomorrow or Wednesday.
Unread 15-02-2011, 18:17
SGS's Avatar
SGS SGS is offline
Please tell me how your testing goes! we would love to hear, also do you know where i could get one relatively quickly?
Unread 15-02-2011, 19:23
Newo95's Avatar
Newo95 Newo95 is offline
AKA: Owen
FRC #0540 (Talon 540)
Newo95 is infamous around these partsNewo95 is infamous around these partsNewo95 is infamous around these parts
We got the 92C. It appears to have a flow rate that starts fast and slows down as pressure builds. It gets to 60psi faster than the old dinosaur sized grey compressors, but it takes longer to get to 120psi. It also has its air intake filter mounted externally. We are reasonably pleased with its performance and very happy with its reduced weight.
--Don't be stupid, it's not smart.
--In conclusion, I conclude that the conclusion was conclusive.
Unread 15-02-2011, 20:21
SGS's Avatar
SGS SGS is offline
We are getting it for the reduced weight as well. Where did you get yours?
Unread 16-02-2011, 00:59
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
I'm not sure where we ended up buying ours because I just found a couple of sources and gave them to the person that buys parts. There were a number of places with the 092C in stock through amazon.com and at Arnottairsuspension.com
Unread 19-02-2011, 17:55
Newo95's Avatar
AKA: Owen
http://www.rjroffroad.com/viair-090c...-pr-17608.html
The 90C will likely be on back order, but you can still get the 92C and 95C.
Unread 19-02-2011, 18:06
klmx30302's Avatar
klmx30302 klmx30302 is offline
Is ready for MAYHEM In Merrimack!
AKA: Kevin McCarthy
FRC #0166 (Chop Shop)
klmx30302 is a jewel in the roughklmx30302 is a jewel in the roughklmx30302 is a jewel in the rough
We got the 95c and have not really tested it other then turning it on to see if it works. To anyone getting these compressors, you may want to consider mounting a fan near/on the compressor to help cool it as they have duty cycles of 9% and get really hot very fast.
Oh and I looked on ebay, there are plenty of 90c, 92c, and 95c compressors on there. Here are a few links:
http://cgi.ebay.com/Viair-90C-12-Volt-Air-Compressor-Kit-NEW-/370484939063?pt=LH_DefaultDomain_0&hash=item56429f 8937
http://cgi.ebay.com/ebaymotors/VIAIR-92c-AIR-COMPRESSOR-120-psi-JEEP-OFFROAD-4x4-RV-_W0QQcmdZViewItemQQhashZitem5ad9bdaa37QQitemZ39020 0142391QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
http://cgi.ebay.com/Viair-95C-12-Volt-Air-Compressor-Kit-NEW-/350359609847?pt=LH_DefaultDomain_0&hash=item51930f 61f7
Hope this helps.
Unofficial Team 166 Videographer
Our team motto...
"THINK!, There must be a harder way!"
Unread 20-02-2011, 23:20
caffel caffel is offline
AKA: Charlie Affel
FRC #0423
caffel is an unknown quantity at this point
Compressor comparisons
We are looking to save weight as well, but concerned about the 1.03 cfm part of the rule.
Compressors are often rated by their CFM at the working pressure.
The Thomas that FIRST sends is rated at .9 cfm, but the Thomas spec says at 0 pounds.
The rule says:
Compressed air for the pneumatic system on the ROBOT must be provided by one and only one compressor. This compressor may be either the compressor from the KOP, or an equivalent compressor that does not exceed any of the KOP compressor performance specifications (specifically: nominal 12v, 1.03 cfm flow rate, 120psi maximum working pressure). Compressed air shall not come from any other source. If an alternative compressor is used, the team may be required to provide documentation to show compliance with the performance specifications
Most of the worthwhile ones under $100 seem to be about 2 cfm.
We will need to watch out for this and its hard to compare them accurately.
Charlie Affel,
Mentor 423
Unread 02-03-2011, 13:59
Newo95's Avatar
AKA: Owen
On a side note, does anyone have the cad for the compressor?
