Go to Post I don't get what all you people have done wrong to make the drills have so many problems. - Cory [more]
Unread 16-02-2011, 01:06
nitneylion452's Avatar
AKA: Joe Lee
Safety Concern
Tonight while we had some people working on our robot (powered on because our programmers were testing sensor readings, but no driving was being done) the robot began to drive one wheel. Nobody was hurt in this incident, but we determined that the cause of this unwarranted driving was a blown black Jaguar speed controller. It appeared to short, but there were no signs of damage on the circuit board of the Jag. Blown Jaguar for no reason. Just wanted to inform everyone to always be careful when working and whenever possible, work with the robot powered off.
Unread 16-02-2011, 01:46
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: Safety Concern
The best option is to turn the robot off, but sometimes that just isn't practical. One way to make sure that you remain safe is to have quick connectors for all your motors. We use Anderson Powerpole's for all our connections, and simply unplug them whenever we are working on the robot while it is on.
Unread 16-02-2011, 01:50
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: Safety Concern
chain is especially dangerous, and a cim will cut a finger off easily.
Unread 16-02-2011, 01:57
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Safety Concern
While powering down is preferred, you can also pull the breakers for your drive motors (or any other subsystem you need to lock out for safety).
Unread 16-02-2011, 02:34
Best Available Data
FRC #1778 (Chill Out!)
Re: Safety Concern
Put blocks under your frame so that the wheels aren't touching the ground whenever it is on and you don't want it to drive.
