Go to Post We really are nerds, aren't we? - Eria4044 [more]
Unread 12-02-2011, 16:48
Write user message displays old data bug
I found that using the Write User Message VI was displaying old data. For example, if it was blank and I sent a 1 then nothing was displayed. Then I sent a 2 and 1 was displayed. Then I sent a 2 again and 2 was displayed.
After digging into the library, the problem is in WPI_DriverStationLCDWrite User Message.vi. The text cache has no dependencies on anything else, and
gets executed prior to setting the line text. This means it sends the previous update's line, not the current update.
I've attached a version which puts the text cache in a sequence structure so that it is called at the correct time. Put it in C:\Program Files\National Instruments\LabVIEW 8.6\vi.lib\Rock Robotics\WPI\DriverStation\DriverStationLCD to fix the problem.
I reported this to the WPILIB tracker http://firstforge.wpi.edu/sf/tracker..._bugs/artf1335
File Type: vi WPI_DriverStationLCDWrite User Message.vi (15.0 KB, 9 views)
Unread 13-02-2011, 07:19
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Re: Write user message displays old data bug
Thanks Joe - I will be the owner of that tracker.
Doug Norman
Unread 16-02-2011, 08:19
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Thanks. I discovered this myself two days ago and I was just going on here to let everyone know. I see you beat me to it.
