Go to Post Life is totally random and there's nothing you can do to change that. - kristen [more]
Unread 15-02-2011, 17:39
captainking's Avatar
captainking captainking is offline
Level 85 Programmer
FRC #0168 (MIB)
captainking is an unknown quantity at this point
PSoC problems
We are having trouble programming our PSoC, we have the right hex file, the program says that the PSoC is connected and powered, but whenever we try to program it we get a message saying
"FAILED! PSoC device is not acquired! Check connection of the chip to the programmer"
We have the 9v battery plugged in
What should we do?
Integrity first
Service before self
Excellence in all we do
Unread 16-02-2011, 09:44
Re: PSoC problems
I don't have any helpful suggestions, sorry. But the board gets its power from the USB connection and the battery should not be necessary.
Unread 16-02-2011, 09:47
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: PSoC problems
What should we do?
BTW, where did you find the hex file? I have been playing with the SoC a while back but couldn't find the hex file.
Unread 16-02-2011, 11:26
Re: PSoC problems
C:\Documents and Settings\All Users\Shared Documents\FRC\FRC_IO.v2.hex
Did you make the mistake of installing the generic Cypress DVD that came with the board?
Unread 16-02-2011, 12:53
mikets's Avatar
Software Engineer
Re: PSoC problems
Yes, I did install the Cypress disc. Should I not? If so, where do I get the proper software?
Thanks.
Unread 16-02-2011, 13:34
Re: PSoC problems
Don't install the Cypress DVD software. It conflicts with the FIRST versions of the same software.
Uninstall and clean out all the Cypress software, then reinstall the Cypress software from the Driver Station Update.
Unread 16-02-2011, 13:35
mikets's Avatar
Software Engineer
Re: PSoC problems
I see. Thanks for the pointer. I will try that tonight.
