Re: Mini-Bot Mangets
Instead of using one or two giant neodymium magnets, use a larger quantity of smaller magnets. It's much safer.
The ones we are using only have a max pull of about 3.5 lbs each, and can easily be pulled apart with your hands. |
We are using two magnets scavenged out of a defunct hard drive mounted about .125 from the pole. Plenty strong and plentiful.
Although we are not currently using them, we are considering using neodymium magnets from an old hard drive, but I have a question about the legality of these. The magnet itself is obviously allowable, but our problem is the way the magnet is mounted to a non-explicitly permitted material; like I said, the magnet is from a hard drive, so it is incredibly securely mounted to a piece of material that acts as a magnetic insulator. I don't want to try to take the magnet off the mount because I am afraid we'll break it, so my question is this: would it be legal to leave the magnet as is and use it on the minibot, or would it not be permitted since the material it is mounted on is not on the list of allowable materials and so is technically illegal?
I'd suggest that if you err, you want to err on the side of caution. If you choose to go the non-caution route, develop a backup plan that can be installed in an hour or two at competition; the inspectors are likely to figure that illegal materials connected to legal materials are still illegal.
You could also try to get the magnets off... but there are some things that may just be really really unsafe/not smart/impractical. What's the mount like, other than really secure? |
Tristan, thank you very much for the golden response. It perfectly addressed the question and was incredibly helpful. Your point about the magnets from a "sold as" point of view is puzzling, as you are exactly correct. I know the magnets in question were some that my Dad removed from an old hard drive, and I don't think it's going to be possible to find a vendor with these exact magnets. In that case, it is a modified hard drive, which would be illegal. I'm going to post this in the Q&A per your suggestion and see what kind of results I get. Thanks again for the great input. Edit: I just searched around on the FIRST Q&A Forum and found someone who asked essentially the same question I did. Here is the response from the game design comittee: Quote:
#7
The magnets from a hard drive can be sheared off their mounting plates relatively easily. Use a large screwdriver to apply the force to the side of the magnet and tap the handle until the magnet pops off. Sometimes, a small part of the magnet remains stuck to the backing plate. The magnet might break into several pieces if you are not lucky. With the going price of dead hard drives being pretty low, you can afford to try this a number of times. All the magnets I have removed seem to be attached with some sort of cyanoacrylate.
Heating the backing plate with a soldering iron may also work. It will not get the magnet hot enough to damage it. I have put these magnets onto red hot steel as part of a heat treating process and they still work fine. Phil |
#8
Also, if the glue is cyanoacrylate, a good soak in acetone might help to loosen it enough to pry off easily. Edit: I removed the erroneous portion of the comment in my post above, lest anyone get confused by it. Last edited by Tristan Lall : 18-02-2011 at 00:11. |
#9
I took the magnets home and my Dad and I managed to remove them without significantly damaging them (a little of the protective outer covering came off, as it got stuck to the mounting plate) by wedging a putty knife under the magnet and tapping it with a hammer to break the seal. Now it's just a matter of trying to figure out how to mount these magnets to the minibot without hurting anyone or magnitizing every tool in our work area in the process!
Thanks for the help, guys! |
#10
The ones in the hard drives I have opened up were not that big so they are not likely to do any real damage, unlike the larger ones.
They are really handy for magnetizing screwdrivers. It makes the screws stick on the end all by themselves, freeing up one of your hands. Just make sure you don't put the magnets in the same pocket you have your wallet since they may wipe out your credit cards. You may want to put them in your wife's purse for the same reason... |
#11
My team and I were considering using magnets on our minibot, but we are concerned that they will induce a charge in the pole when the minibot moves. Has this been a problem for anyone using magnets on their minibot?
#12
We're using fairly strong magnets and have not encountered this.
#13
I am not exactly sure which type of magnets we use, but what i do know is that they are pretty strong, but probably not as strong as some teams use. When mounting them, we are incredibly close to the pole, less than 1/16 in. This has allowed us to have a relatively safe and light magnet and still have enough traction for a sub 2 second minibot. We used two total, however only one really applies traction, the other makes sure we track straight up the pole.
#14
Hello Matt
Perhaps soaking in solvent is the way to go even though it would be much slower. I just read a datasheet for some neodydmium magnets last night and they indicated the magnets would start to lose magnetic strength above a surprisingly low temperature. I don't recall the exact number but it was something like 80C. I am sure the industrial heat gun gets hotter than that since we were charring the solid maple workbench with the blast. Unfortunately, I don't recall which manufacturer posted this data (it was pretty late). We also noticed that the pulling force of the magnets that we measured seem to decrease to a fraction after removal from the backing plates. This observation applied to the ones we heated as well as the ones we sheared off. We suspect that the backing plates are some sort of high-permeability steel and they concentrate the magnetic flux. They look rather thick for the mechanical stresses involved. Another strange phenomenon we noticed is that the magnets seem to be magnetized in zones along the arc. The pair of magnets from one hard drive would stack nicely but magnets from another (different brand/model) would only stack with an offset. In the past, I had noticed this same effect with strips of flexible magnets. Since we could not get the pulling force we needed with the magnets from the dead hard drives we now have some on order from an online supplier. |
#15
1519 is using two Neodymium magnets also...
As always, be careful with high-strength magnets! I do recommend using a smaller magnet at a closer distance (partly for weight, but primarily for safety). We didn't have any trouble mounting ours ~.125" from the pole, and the two of them have only 23 pounds of force each! Here's the link for the ones we used: http://www.kjmagnetics.com/proddetai...884DCS&cat=173 Some recommendations: - Use ones with countersunk holes... they make mounting them a charm! - Mount closer to the pole (3/16" or less), to minimize the weight of the magnet you have to lift and reduce the danger from having a higher-strength magnet. - Not that important, but the narrower your magnets are the more of the magnet is at the minimum distance from the circular pole. - Spread them out over the length of the minibot, if possible. This will help create a longer moment for your resistance to the minibot driving up the pole at an angle. We relied more on near-perfectly balanced weight to achieve a straight ascension. Best of luck, the magnets really made our design possible! And here are some links of our minibot climbing: Climb Only: http://www.youtube.com/watch?v=3Ht0gHEOb14 Slowed Down Minibot Race at GSR: http://www.youtube.com/watch?v=Dl55U1PuDKM Thanks to Joe Barra from Team 20 for posting (http://www.chiefdelphi.com/forums/sh...59&postcount=1) the second video. Last edited by Nathan Streeter : 07-03-2011 at 17:08. Reason: Adding video links... |
