Go to Post You know you have bad field problems if both Dean and Woodie come out to try to fix them... :) - tim_reiher [more]
Unread 14-02-2011, 21:20
rabridges's Avatar
rabridges rabridges is offline
AKA: Antron
FRC #0395 (2 Train Robotics)
rabridges will become famous soon enough
pic: Team 395 Unfinished test phase Robot
Unread 14-02-2011, 21:23
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Re: pic: Team 395 Unfinished test phase Robot
Looks like another awesome bot from 2 train. the grabber reminds me a lot of plague's bot from 07, and the way you've mounted your gearboxes is pretty cool. wouldnt have thought of using the am shifters for mecanum.
Do you guys have the shifting if so have you found it useful with mecanum? and I cant tell from the photo but can you score up top?
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 15-02-2011, 02:25
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
on your lift what type of planetary gear boxes are you using and where did you get them?
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
Unread 15-02-2011, 02:49
Looks like a pair of AndyMark planetaries, most likely 2-3 stage GEM500s. Run through a Toughbox, too--that's kind of an interesting setup. Stock Tougbox ratio or custom?
Unread 16-02-2011, 03:51
ttakashima's Avatar
T^2
AKA: Travis
Those Gem 500s are huge, 2 wont fit on a toughbox like those 2 are, unless the box is somehow elongated or the GEMs are cut down. Those look a little smaller, kinda like the FP ones you get on AM. But the ones pictured are fully covered. Maybe an added sleeve?
Travis Takashima
Team 2504 Alum 09'
Attending
Unread 16-02-2011, 11:24
I dunno--the FP ones don't have as long of a sleeve as these do, and there's what looks like an AM sticker on the side of one of them. Might be a stacked set of something like http://www.andymark.com/ProductDetai...ctCode=am-0823 and http://www.andymark.com/ProductDetai...ctCode=am-0301.
Also, I'm pretty sure the GEM500s are about the same size as CIMs, and two CIMs fit on a Toughbox with a little room to spare.
Unread 16-02-2011, 11:28
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Those are the old style AM planetaries. The housing is different but the guts are the same.
Unread 16-02-2011, 13:34
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Those aren't shifting gearboxes? Looks like a custom gearbox using two stages of reduction via belt. Pretty nice implementation too.
-Dustin Benedict
Unread 16-02-2011, 14:00
jblay's Avatar
AKA: Joe Blay
Touche fro. But at first glance you have to admit they kinda look the am shifters. Really cool mounting nonetheless.
Unread 24-02-2011, 22:22
rabridges's Avatar
AKA: Antron
No Shifter, just belts driven pods and the robot is awesome. Mecanum is a first for us, I'll post more picture later. Thank you for your comment.
Unread 24-02-2011, 22:24
rabridges's Avatar
AKA: Antron
No gears, just belts.
Unread 24-02-2011, 22:26
rabridges's Avatar
AKA: Antron
Andy Mark is correct
Unread 24-02-2011, 22:28
rabridges's Avatar
AKA: Antron
I forgot where, most likely Andy Mark.
