Go to Post However, as a philosopher, while you need math, you can probably talk your way out of it. - sciguy125 [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 16-02-2011, 11:41
IanG IanG is offline
FRC #1535 (The Knights of Alloy)
IanG is an unknown quantity at this point
Re: Defective Black Jaguars?
We had an issue like that on 2 different black jags. We just flashed the firmware again and they worked fine
Unread 20-08-2011, 17:56
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
I know this is old, but I want to post my (odd) results.
When we re-flashed them, they worked fine, and I forgot about this for a while, until I flashed one again, and it did not work. After some testing I discovered this pattern:
Flash -> works
Re-Flash -> does not work
Re-Flash -> works
Re-Flash -> works
Re-Flash -> works
etc...
Watchdog.Kill();
Unread 20-08-2011, 19:06
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
It appears that re-flashing a working Jaguar will fail, causing that Jaguar to not work. Maybe something to do with the bootloader.
-- Marshal Horn
Unread 21-08-2011, 23:28
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is online now
AKA: Alan Wells
FRC #1350 (Rambots)
If this pattern is the case for all jaguars, I would think that the manufacturer would want to know about this since it seems like a resolvable issue (even if the solution is just to release a notice to users about the existence of this phenomenon).
