Go to Post Welcome to CD, side effects aren't limited too, but may include, addiction to mechanical and electrical assemblies, desire to program in C, drawing objects in Solidworks and subconscious learning! - Jay H 237 [more]
Unread 16-02-2011, 13:00
elbuo elbuo is offline
Teams #2884 and #1144
AKA: Yamil Asusta
FRC #1144 (Coquitron)
elbuo has a spectacular aura aboutelbuo has a spectacular aura aboutelbuo has a spectacular aura about
Same circuit allowed?
I'm trying to figure out if I'm allowed to include 2 relays on the same circuit. They will both be protected by a 20A fuse in the PDB and they will include their provided 20A fuse also.
Also, would I be able to do the same thing with my proxes. Wire them together in the same circuit and protected with the required 20A fuse they will need.
Unread 16-02-2011, 13:07
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Same circuit allowed?
no.
<R39> All active PD Board branch circuits shall be protected from overload with an appropriate value auto resetting Snap Action circuit breaker (from the KOP or identical equivalent).
B. Each relay module branch circuit must be protected with one and only one 20-amp circuit breaker on the PD Board. No other electrical load can be connected to the breaker supplying this circuit.
Unread 16-02-2011, 13:22
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
Looks like IndySam is right about <R39> and the relays. Maybe you could tell us what your need for this for this sort of configuration is?
I don't see anything wrong with the second part.
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 16-02-2011, 13:23
AKA: Yamil Asusta
Same rules I read last night.
It doesn't say that you are not allowed to have them in the same circuit. They will all be under the rules regarding fuses. They will all be connected to the same fuse therefore it adheres to the rules.
From what I'm understanding every relay must be protected by 1 and only 1 20A Fuse. Therefore they will be protected under the same fuse.
Unread 16-02-2011, 13:29
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
The rules also say that each relay has to have the breaker, and no other electrical load may be connected. As far as I understand, another relay is another electrical load.
Matt Krass
Unread 16-02-2011, 13:30
IndySam's Avatar
I guess I misread your question. I figured you were talking about spikes. If you are talking about two regular relays I guess they would be considered part of the same custom circuit.
If you could explain what you are trying to do, there are some great electrical minds (mine not included) here that can tell you if you can or even should.
Unread 16-02-2011, 13:33
Power User
AKA: Carl Agnew
The potential problem lies within the second part of the rule.
<R39>B. Each relay module branch circuit must be protected with one and only one 20-amp circuit breaker on the PD Board. No other electrical load can be connected to the breaker supplying this circuit.
Perhaps if you provided a circuit diagram or:
  1. explained what two relays are doing in a singe circuit that one couldn't do, or
  2. explained why the relays can't connect to separate 20A ports on the PD board
Unread 16-02-2011, 13:35
AKA: Yamil Asusta
I was talking about Spikes.
If another relay in the same circuit as a relay already installed is considered an electrical load then I guess the rule applies to it.
Their us is to control LEDs.
We believe there is not reason to connect them separately and we are trying to save some spots for motors and additional electrical loads such as proxes. If the proxes can be wired together under the same circuit then we won't mind about the relays.
And related to the proxes? Are they allowed to be connected in the same circuit under the same fuse?
Unread 16-02-2011, 13:42
Matt Krass's Avatar
AKA: Dark Ages
I assume by "proxes" you mean the photosensors? Or is this another part I'm not recognizing?
Those can be connected to the same circuit because they individually draw very little power, and a 20A circuit breaker is very excessive. They also have integrated short circuit protection.
Spike relays on the other hand could be potentially switching up to 20A per relay, and multiple ones could easily overload a single 20A breaker. I understand your particular application doesn't pose this risk, but the rules must be able to apply broadly to be effective. As such, to the best of my understanding, you can only have one Spike per breaker.
You may have better luck considering a custom circuit board option for your LEDs, a little bit of LEDs, resistors and standard transistors from RadioShack and you could be in business with a single power soure and a couple of Digital Outputs. If you need help with that idea, let us know!
Matt
Matt Krass
Unread 16-02-2011, 13:47
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
If "proxes" are some type of proximity sensor or the Kit photosensors then they may be connected together to a single 20A breaker. The power wires for each device should be spliced together so only a single wire is inserted into the WAGO terminals on the Power Distribution Board.
Unread 19-02-2011, 08:41
If you check the operations manual for the Spike you will see that you can control two loads with one Spike. Other wise, only one Spike per PD output please.
