Go to Post and don't overestimate the ability of an unskilled fool with exotic tools! - MissInformation [more]
Unread 16-02-2011, 14:51
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Source Code for Smartdashboard?
How are you having two cameras? if you have one or more on the switch, you can even use ZomB, which has support for as many cameras as your computer can handle If you drag a camera on, it is by default accepting stuff from WPILib's built in camera. under source, you can change it to MJPEG, and enter the IP address of a camera connected to the switch in the box below. No source changes needed.
Watchdog.Kill();
