Go to Post These teams aren't elitists, but they sure are elite. - [more]
Unread 16-02-2011, 15:08
RoboElite640 RoboElite640 is offline
FRC #0640
RoboElite640 is an unknown quantity at this point
robotDrive.drive help?
So we had the program work so that if (stickRight.getRawButton(1) == true)
{robotDrive.drive(1.0,0.0); }
if (stickLeft.getRawButton(1) == true)_
{robotDrive.drive(0.2,0.0); }
but when we try this it works partially. When we push button 1 on stickRight, it moves faster but only one motor moves faster. Vice versa with button 1 on stickLeft, only one motor moves slow. Any help?
Unread 16-02-2011, 16:28
xinchi.he's Avatar
xinchi.he xinchi.he is offline
AKA: Xinchi He
FRC #1209
xinchi.he is an unknown quantity at this point
Send a message via MSN to xinchi.he
Re: robotDrive.drive help?
try robotDrive.arcadeDrive(speed,turn);
Unread 16-02-2011, 21:10
FRC #0640
well, i didnt get a chance to try that, but essentially I'm trying to have it set up so that when i press one button the robot will drive faster. And if i press another button the robot will drive slower.
Unread 17-02-2011, 10:07
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Ah, okay. What you're doing in the code above is basically autonomous. It'll just drive instead of powering the motors to a set limit.
I'd recommend having your program use Jaguar objects in your Drive train instead of integers (assuming you are using int's)
Once you do this you should be able to limit it in teleop.
RobotDrive drive = new RobotDrive(leftMotor, rightMotor);
if(leftMotor.get() >= 0.5) {
    leftMotor.set(0.5);
} else if(rightMotor.get() >= 0.5) {
    rightMotor.set(0.5);
// then call your drive methods and it'll limit the max speed to 0.5
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 17-02-2011, 11:19
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
The other advice given has been good but don't address directly your statement that only one motor works in each case. The 'if' control statements shouldn't affect the .drive that way regardless of your reason for wantign to do it. What does your RobotDrive constructor call look like?
