#31
Re: 816 - 90% Complete (Video inside)
I just ordered a 1.25" OD x .083" wall 2024 Aluminum Round Tube. We'll swap it in on our practice robot tomorrow and see how things go. Also, for what it's worth, we've been running our motor at 40% of its full power. It's otherwise too fast. |
#32
What speed does 40% power (I'm assuming 40% signal) equate to? I know that at 100% signal our arm goes up in ~1 - 1.1 seconds (90* per second), but we usually go up in around 2 seconds because it's more controllable. |
#33
Great Job Guys! I am always amazed at what your team is able to come up with every single year! Its always effective, simple , and a marvel among all teams. I wouldn't be surprised to see you guys go very far into Saturday like every year. Awesome job!
See you at The NJ Regional!! |
#34
We are running a similar mechanism with an rs550 motor in a 256:1 gearbox with a 2:1 reduction after the gearbox. Are you able to backdrive the gearbox when the robot is off?
It does not seem possible with our robot. |
#35
Our current setup is as follows: 1 RS775 Motor in a 256:1 P60 Gearbox on each side of our tower (total of two), each with a 15 tooth sprocket that drives a 48 tooth sprocket on our arm for an effective ratio of 3.2:1 from the transmission or an 819.2:1 reduction from the motor. We also have a decent amount of surgical tubing on our arm as an assist which also makes the mechanism harder to back drive. We're swapping out out the 15 tooth sprocket on our transmission for a 10 tooth sprocket tonight, which makes the ratio 4.8:1 from the transmission or 1228.8:1 from the motor. I'll report back tonight or tomorrow if this changes the ability to back drive the arm. Also, how much, if any, assist is on your arm? Enough springs or gas struts would make the arm nearly impossible to back drive by hand. You can also look for sources of inefficiency (binding, improper shaft alignment, etc.) and see if that is adding extra resistance which would make the arm harder to back drive. FYI, as the banebot transmissions start to fail, they will become nearly impossible to back drive without power. Check your transmissions too. |
#36
![]() Incase you want a comparison (in no way am I trying to brag): We are running a 256:1 w/ a 550 motor and a 12:25 after giving ~533:1. Our arm will hold its position in about 30 degrees of motion only from the surgical tubing. It holds fine in all parts with the motor connected. We also upgraded to aluminium arms with the same OD (1") and half the wall thickness. They are slightly heavier (~20%) than the pvc setup we had. BTW, your bot looks great. I hope to see it sometime in person. I am also a fan of anything orange too. |
