#16
Re: 3 position cylinders
3 port center port closed solenoid valves were illegal because they trapped pressure and would not allow the full pressure to be relieved. Why can't you add addition pressure relief surge valves to the line to the cylinder and accomplish the same thing? Might be a good question to ask the GDC..
#17
Center closed solenoid valve would keep a pneumatically actuated arm locked wherever it is, even if robot power or pneumatic pressure is removed. Any other configuration of valves results in a robot appendage that can move when solenoid power is lost (breaker, or field disabled), or when air pressure is lost (dump valve opened). I'm certain many teams can attest to needing to teach their students to be aware of robot actions that can occur when the pneumatic system gains and loses power. |
#18
center blocking/locking valves have been deemed illegal.
#21
So what does everyone think? Are the 3 position pistons legal, using only solenoids of the type supplied in the KoP?
#22
we are making our own "three position pistons" and betting the farm that they are legal.
#23
Yeah, that would probably be legal, since they are two totally seperate cylinders, and each one is controlled by a seperate solenoid.
#24
