Go to Post Note that these comments are based on the 2006 FRC game rules, and they may or may not apply to the 2007 game. Your mileage may vary. - dlavery [more]
Unread 15-02-2011, 18:17
Unoquadium Unoquadium is offline
The Parlor Generals
AKA: Ilya Rubnich
FRC #0334 (Tech Knights)
Unoquadium is an unknown quantity at this point
Question Hooking Up a Micro Switch
So we need to somehow plug a limit switch (Micro Switch) into the robot. I heard stuff about plugging it into an analog input board and other stuff about plugging it into the digital sidecar and we don't know which one it is.
Can someone clear this up for us? We ultimately just need to get a 0 or 1 output from it.
Thanks.
Unread 15-02-2011, 19:10
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: Hooking Up a Micro Switch
Connect it to a digital input on the digital sidecar. One side of the switch should go to ground, the other to the signal line. The +5V line is unused, since the digital inputs have internal pullup resistors.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 16-02-2011, 16:40
The Parlor Generals
AKA: Ilya Rubnich
The switch has 3 contacts, NC2, NC3, and COM1. Which one would go to signal and which one to ground?
Unread 16-02-2011, 19:11
Read the labels again. I think you'll find that terminal 1 is labeled COM (for COMmon), terminal 2 is NC (for Normally Closed), and terminal 3 is NO (for Normally Open).
Typically, COM is connected to ground, and either NC or NO is connected to signal depending on whether you want the input to read "true" or "false" when the switch is activated.
Unread 21-02-2011, 01:28
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Originally Posted by Alan Anderson View Post
Typically, COM is connected to ground...
Although it doesn't matter if you connect COM to common (ground/black) and NC/NO to signal.
If you're looking to use the microswitch as a true limit switch to stop the motor and you're using the CAN bus, look into wiring the switch up to the jaguar itself. It's much safer because it's a hardware thing (it's also faster, so no more bent/crushed switches).
