Go to Post TL;DR: The robot battery (and your car battery) aren't going to electrocute you unless you stab a positive and negative wire from them into your heart. In which case you have plenty of other problems besides. - Kevin Sevcik [more]
Unread 16-02-2011, 16:53
Tds123's Avatar
Tds123 Tds123 is offline
There is no I in team =]
AKA: Timothy Shub
FRC #1396 (Pyrobots)
Tds123 is an unknown quantity at this point
Send a message via AIM to Tds123
controling pistons
Could someone please tell us how to use the piston magnets that we recieved with our bimba order? Also could you state what the proper use is for them? Thank you.
ThE sCaLeS oF bAlAnCe (Team 1396)
Unread 16-02-2011, 16:59
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: controling pistons
First off, it's a cylinder
What you recieved is not a magnet but a reed (proximity) switch. The cylinder has the magnet at the end of the rod and the reed switches will detect when the rod end (internal to the cylinter) is within proximity.
The reed switches can tell your controkl system what state (retracted or extended) your cylinder is in ... and if it'd fully extended (/retracted)
___________________
- Tennyson, Ulysses
