Go to Post Remember, if FIRST is your top priority, you need to look at your priorities. - Billfred [more]
Unread 16-02-2011, 17:00
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: 3 position cylinders
Originally Posted by 1075guy View Post
Which is odd, because a center-closed valve doesn't trap any usable pressure. If you closed off a center-stop solenoid (trapping the air in the cylinder to keep the cylinder locked in one position), removed the air pressure from the P port (ie. open the dump valve) and then simultaneously open both sides to atmosphere, nothing will happen, except that gravity might take over, and actuate the cylinder. I think this is another case of the GDC being closed minded and limiting innovation they've allowed in the past, citing a rule intended to provide safety, when their rule arguably makes things less safe.
Center closed solenoid valve would keep a pneumatically actuated arm locked wherever it is, even if robot power or pneumatic pressure is removed. Any other configuration of valves results in a robot appendage that can move when solenoid power is lost (breaker, or field disabled), or when air pressure is lost (dump valve opened). I'm certain many teams can attest to needing to teach their students to be aware of robot actions that can occur when the pneumatic system gains and loses power.
This was my thought process as well. I have taken the approach that I need to expend my energy working on a solution rather than railing at the lack of sense the GDC is making. Rules are rules after all. My team would have been much better off if we had read the rules better at the beginning of the year. Oh, well...
