Go to Post I don't resent or envy them for being strong teams; I hope we can continue to learn from them and someday join their ranks. - dsmoker [more]
Unread 16-02-2011, 17:18
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Robot Arm Victor Motor
Our team's mechanical engineer insist's our arm not working is a program error. I don't think so, so I just want to double check here.
Victor arm;
public void robotMain() {
    arm = new Victor(10);
public void operatorControl() {
    while(isOperatorControl()) {
        getWatchdog().setEnabled(true);
        getWatchdog().feed();
        if(joy.getRawButton(10)) {
            arm.set(-0.2); // arm goes down.
        } else if(joy.getRawButton(11)) {
            arm.set(0.2); // arm goes up.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 16-02-2011, 17:24
Re: Robot Arm Victor Motor
Can you describe what the problem with the arm is? Just looking at the code, once the arm starts moving, the arm will always be moving in one direction or the other, which might not be desirable.
Unread 16-02-2011, 17:30
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
        } else {
            arm.set(0);
Did you check the pwm?
class team2412(GP):
    def __init__(self):
        GP.__init__(self)
        self.coopertition = True
        self.info = {"name": "Robototes", "school": "Sammamish High School, Bellevue, WA"}
        assert self.kind_people == True
Unread 16-02-2011, 18:05
Sorry, I mean the arm doesn't move at all.
It is plugged in to channel 10.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 16-02-2011, 19:24
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Can you show us where you initialize arm? That may be the problem.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 16-02-2011, 19:55
All arm-related code is given above. It is initalized in the robotMain function.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 16-02-2011, 20:06
Here's a number of non-code related things that could cause a motor not to move:
You didn't enable the robot on the driver station
You didn't plug the PWM cables from the victor to the digital sidecar PWM ports
The PWM cable missed the connector inside the shroud on the victor (this is very easy to do).
You didn't power the digital sidecar
The digital sidecar isn't plugged into the digital module in slot 4 of the cRIO
You have the PWM cables plugged in backwards. B is for black wire.
You have the PWM cables plugged into the wrong PWM ports on the digital sidecar.
The circuit breaker is immediately tripping.
The speed controller isn't powered.
The motor isn't connected to the speed controller.
Knowing what the LED is doing on the speed controller would help narrow down the problem
Unread 17-02-2011, 08:49
We covered the majority of those grounds last night. We plan on re-checking today after school.
However, the motor is getting power, and is blinking orange.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 17-02-2011, 08:56
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Are you sure you are pushing "Button 10 and Button 11"?
For laughs and tickles try using the joystick value to eliminate any posability that it is the mechanical/elecrtical problems.
x2 on checking the connection of the pwm cable.
I hated redoing pwm cables on the victors they always seem to not go into the header when you need it to!
Unread 17-02-2011, 09:01
Jared Russell's Avatar
Taking a year (mostly) off
Blinking orange on the Victor suggests a problem with the PWM cable connection (or you never initialized "arm").
Unread 17-02-2011, 09:14
In the actual code we had only done:
Victor arm = new Victor(10);
outside of robotMain. Could that actually be the problem? I never thought it mattered.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 17-02-2011, 11:27
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Are you sure that 0.2 will overcome the inertia of the arm? Do the motors hum or get warm at all? You can test the output side of the victor with a multimeter.
Unread 17-02-2011, 11:39
The multimeter shows no change.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 17-02-2011, 11:55
AKA: Jim O'Malley
The code shown is too simple to be 'wrong'. (though the addition of else ... 0.0 is a good idea).
The initialization issue mentioned by Jared341 would throw an exception (null pointer) in most, but not all cases. You need to make sure the object stays in scope all the time. Its not clear from your response to him if it does or not. Are you leaving the scope of the declaration right after setting the motor for instance? That would show no errors and not work.
Unread 17-02-2011, 12:04
What do you mean "leaving the scope"?
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
