Go to Post It's hilarious to watch this conversation about a box which probably has a 95% chance of being robot batteries turn into all kinds of bowling ball conspiracies. - artdutra04 [more]
Unread 16-02-2011, 13:08
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
Re: servo
I am also having trouble connecting the unbundled buttons going through the case structure and into the motor set output vi.
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
Unread 16-02-2011, 13:39
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: servo
A Joystick button returns a boolean. The motor set output requires a number. If you want to feed the numeric value of a boolean (0 or 1) into the set output VI (this would run a motor in one direction whenever the button is held and stop it when released there is a small VI block that will do the conversion.
I don't have Labview in front of me here at work, but I would guess that it is in the Boolean palette and if I recall correctly has "0:1" on the icon.
Unread 16-02-2011, 14:04
Re: servo
When you get the chance, can you modify the attachment i added before and show me that.
Unread 16-02-2011, 14:09
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: servo
I head straight from work over to the school to work with 3573 where I don't have Internet access. I will take a look at the attached code when I get home this evening (6 or 7 ET).
Unread 16-02-2011, 17:05
Re: servo
that is great, thanks.
Unread 16-02-2011, 17:29
Re: servo
When i attach the green button wire to the sync group input on the set output motor vi, it just says that it's error wire. that the wire does not match the vi input.
Unread 16-02-2011, 18:33
Re: servo
any other homemade diagrams would be welcome too
Unread 16-02-2011, 19:46
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: servo
A While Loop in Teleop set to run once with nothing passed in or out has no real purpose. I would remove it for ease of reading.
Your servo code creates a race condition. You are setting the value two separate times with two separate pieces of code. Where the servo will end up is not determinate and may not be consistent. I have shown one way of wiring the up and down commands using a single Servo Set VI. You should be able to follow that example to fix the left-right servo code.
I have included an example of controlling a motor with a joystick y-axis, a button that runs it one direction and two buttons that run it in opposite directions.
The PWM channels are specified when you open the device in Begin.VI. I have included an example of how to open a motor and set the refnum in the attached teleop file but this is NOT where that code should go in your project. It must be done in Begin.
Sync groups are an advanced function used with CAN that you don't need to worry about right now. You want to be wiring into the terminal labeled "output" on the Motor Set Output VI.
If you have any other questions or are having difficulty understanding any of the examples please feel free to ask.
Unread 16-02-2011, 19:53
Re: servo
omg thank you so much!!!!you are awsome!!!!!!hopefully we will see you at the nationals.
Unread 17-02-2011, 16:31
Re: servo
And how do i program an arm in autonomous, example pleeeeeeeeeeeeease. say i want to wait 6 seconds for the arm to move up for 3 seconds.
Unread 17-02-2011, 17:55
Re: servo
and how do i make a motor move for some odd amount of seconds and then stop.
