Go to Post There's a fine line between cockiness and confidence. Confidence is one of the major keys to success and happiness in life. As long as one can carefully stay on the right side of the line, staying connfident while remaining humble, and ego can be quite beneficial. - Karthik [more]
Unread 15-02-2011, 23:22
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Encoder fixed in WPILib 2011?
Originally Posted by Jeanne Boyarsky View Post
How did you create the first (dummy) encoder? Instantiating using the same arguments gives channel in use errors, no?
I wrote a (fairly quick) VI that takes A phase, B phase, and count scaler and outputs a working encoder. It creates the dummy using the same channels on slot 6, then creates the real one on slot 4. It assumes 1x decoding since that's what we use.
I haven't tested it heavily (still working on mechanism tuning, we haven't tuned the drivetrain yet), so I am hesitant to post it here.
Quick answer:
Create one on slot 6 and one on slot 4. Since we don't use slot 6, that solves all of our problems.
Kettering Motorsports
Unread 16-02-2011, 15:03
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
If you instantiate the DigitalInputs first, then pass those into the encoder constructors, you will not get the errors. The errors happen when the encoder tries to construct DigitalInputs for the same channels more than once.
By the way, I found that it is not always the second (odd) decoder that works.
See this thread.
In 4x mode, the 2 odd ones work. In 2x or 1x mode, the first 3 even ones work and the last one (odd) works.
-Joe
Unread 16-02-2011, 17:40
Jeanne Boyarsky Jeanne Boyarsky is offline
Java Mentor
FRC #0694 (StuyPulse)
Jeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud of
Joe,
We got it. It was encoders #1, 3, 5 and 8 that worked. Should have checked this thread before trial and error! This is so illogical, but good it is consistent.
We did have to use different distinct channels for all four dummy encoders. But that's ok.
Team 694 mentor 2010-present, FIRST Volunteer and Co-organizer of FIRST World Maker Faire Tent
2012 NYC Woodie Flowers Finalist
2015 NYC Volunteer of the Year
Unread 16-02-2011, 18:16
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Is it possible to set the dummy to a slot besides 6 or 4 that are meant for the Digital Side Car? This year my team is using 2 digital side cars so it would be nice to set it to an unused slot.
Unread 16-02-2011, 18:38
You don't need to use a different slot at all... read this post. Construct the DigitalInputs first.
-Joe
Unread 16-02-2011, 18:40
MagiChau's Avatar
AKA: Michael Chau
-Joe
Sorry about that, unlike me to not notice that post.
