Go to Post Weird. On a forum where people talk about robots, we have a robot trying to talk to people. - dellagd [more]
Unread 16-02-2011, 18:42
sonicwingmode sonicwingmode is offline
FRC #3404
sonicwingmode is an unknown quantity at this point
how to program mecanum wheel drive?
our team searched the forums and found how to start program a mecanum wheel drive, but we are stuck.
http://www.chiefdelphi.com/forums/sh....php?p=1020714
We can't find the Mecanum Drive block. Do we have to download the Mecanum Drive block or do we have to make the program from scratch?
Unread 16-02-2011, 21:54
bmxer51 bmxer51 is offline
FRC #2874
bmxer51 is an unknown quantity at this point
Re: how to program mecanum wheel drive?
We also use mecanum wheels and last year our program was terrible. We have a pretty decent program this year after i sat down and learned labview. What controls are you using? We are using an xbox controller but it would be very simple to change it to the two joysticks provided in the kit. If you could give me that info I could help you come up with your equations to write for each wheel.
Unread 16-02-2011, 21:59
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
Wink Re: how to program mecanum wheel drive?
When you say "block" I am going to assume that you are programing in labview. If you are available tomorrow (or today), I can help you program it using remote desktop software if that's ok with you. Send an email to therobotmaker@gmail.com if you are interested.
Unread 16-02-2011, 22:35
There's a Search button at the top of the Functions Palette. It'll show you where to find anything you can name. In this case, the name of the function you're looking for is actually Holonomic Drive.
Unread 17-02-2011, 08:30
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
i looked through the robot drive function and there is a mechanum drive...
Unread 17-02-2011, 09:59
See attached screenshots.
ID:	10159  Click image for larger version
Name:	functions palette.png
ID:	10161  Click image for larger version
Name:	mec cart vi help.png
Unread 17-02-2011, 15:32
FRC #3404
oh! there it is, I'm going to try to program it
Unread 18-02-2011, 19:34
FRC #3404
what do we put in the rotation?
Unread 18-02-2011, 23:43
Owen Meaker Owen Meaker is offline
FRC #4180
Owen Meaker is an unknown quantity at this point
rotation is the, well, rotation of the robot. If you have a joystick that can be twisted, you can use that (for our joystick its axis 4, but it could be different for other joysticks). If your joystick does not support twisting, you will need to have buttons that are wired in (for example, put in a case structure that determines which button is being pressed, that then outputs a 1 or -1 depending on which way you want to rotate it).
Unread 19-02-2011, 00:00
kornjones kornjones is offline
AKA: samuel
FRC #1522 (DOTM)
kornjones is an unknown quantity at this point
My team has been using mecanums for a few years and at the beginning of the year an alumni asked me to make a program that could take full advantage of the mecanum wheels instead of our usual tank drive with trigger strafe boringness. after much thought and many matrices i realized that if you subtract the y axis form the x axis for the front right and back left and add y and x axes for the front right and back left we could make what i like to call omnidrive. it basically made it so that the robot would move in any direction the stick was pointing. after some more finagling i put the controls on two sticks and fixed a few value issues and now we have 2 stick mecanum omnidrive. its pretty difficult to explain but its fantastic to drive. if anyone needs any help i am also available for assistance
Unread 19-02-2011, 09:11
What you have described has no rotation. Perhaps you left something out of your description?
Also, I assume there's a typo in there, because you said "front right and back left" twice.
Unread 19-02-2011, 16:23
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
That picture should make it fairly obvious. If not, look below. mainJoy is the one used for forward/back and strafing, rotJoy is used for rotation (pretty much like a FPS game, we even wired our camera's tilt up to rotJoy's Y axis so it is exactly like the usual FPS controls ) For best results, use an Xbox/PS3 controller. Remember forward is -1.
Assuming you get -1..1:
front_Left = -mainJoy.getY() - rotJoy.getX() + mainJoy.getX()
front_Right = -mainJoy.getY() + rotJoy.getX() - mainJoy.getX()
back_Left = -mainJoy.getY() - rotJoy.getX() - mainJoy.getX()
back_Right = -mainJoy.getY() + rotJoy.getX() + mainJoy.getX()
Unread 19-02-2011, 16:38
Originally Posted by sjspry View Post
mainJoy is the one used for forward/back and strafing, rotJoy is used for rotation... Remember forward is -1.
Two suggestions:
1) I would think it would be more intuitive if pushing rotJoy to the right would cause clockwise rotation*.
2) You need to normalize the 4 wheel commands, in a way that preserves their holonomic relationship, before sending them to the motors.
* I am assuming that the motors are set up so that issuing a + command causes the wheels to rotate in the "forward" direction
Unread 19-02-2011, 17:23
FRC #1984
Two suggestions:
As for #1, yeah, as far as I know everything should be backwards because of the Joystick output. They might need to modify it....
Didn't know about the handy PDF, though. Thanks
Unread 19-02-2011, 23:23
The joystick X-axis is + to the right. So your code should be
front_Left = -mainJoy.getY() + rotJoy.getX() + mainJoy.getX()
front_Right = -mainJoy.getY() - rotJoy.getX() - mainJoy.getX()
back_Left = -mainJoy.getY() + rotJoy.getX() - mainJoy.getX()
back_Right = -mainJoy.getY() - rotJoy.getX() + mainJoy.getX()
