Go to Post Limits are imposed by both man and nature. Understanding those limits and attempting to push past them is the basis of creativity. - Dave.Norton [more]
Unread 16-02-2011, 16:28
Superllama12's Avatar
Superllama12 Superllama12 is offline
Wombaticus
AKA: Brandon Buncher
FRC #0540 (Talon 540)
Team Role: Electrical
Superllama12 is an unknown quantity at this point
Spike Placement?
Does anyone know if there is a minimum distance between spikes/relays with each other, or any minimum distance between any two electrical components? I searched the manual and found nothing, but people on my team have been talking about it. Thanks!
I would put a signature here, but that's too mainstream
Wait a moment...
Unread 16-02-2011, 16:39
JDL JDL is offline
Systems Integrator
FRC #0498
JDL is just really niceJDL is just really niceJDL is just really niceJDL is just really nice
Re: Spike Placement?
I don't believe such a rule exists. Obviously some common sense should be applied to laying out the electrical, you got to be able to get the wires/connectors onto the connections and you are going to need wire bending room.
Unread 16-02-2011, 17:07
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
For spikes there isn't any minimum distance other than enough so you don't short your connectors. For Victors and Jaguars, however, you do want to space them out a little. The difference here is heat. Victors and Jaguars generate fairly significant amounts of heat, thus the muffin fans integral to both of them. They require some amount of space to allow the fans to work. Since Spikes don't really generate much heat, they don't have fans and don't require any space in order to properly dissipate heat.
Unread 16-02-2011, 18:47
Wombaticus
Thank you both so much!
Wait a moment...
