Go to Post 15 thread derailment points - EmileH [more]
Unread 16-02-2011, 21:21
JoeyPass JoeyPass is offline
FRC #2169 (KING TeC)
JoeyPass will become famous soon enoughJoeyPass will become famous soon enough
Compressor Problem
We are using the new compressor and it has been cutting out intermittentantly. Simultaneously the status light would go out. Yesterday we isolated the PWM going into the spike relay as loose and once in a tighter fit both the light and compressor worked. Today at initial startup the compressor and ligh worked for about 5 seconds and then nothing from either. We replaced PWM's for both the spike and the relief valve, tried a different compressor, tried sample compressor code, tried a new spike...
Has anyone else had this problem or do you have any suggestions. '
Thanks in advance,
