Go to Post NEMO is a virtual organization with a virtual headquarters and virtual bank account. - KathieK [more]
Unread 16-02-2011, 21:21
JoeyPass JoeyPass is offline
FRC #2169 (KING TeC)
JoeyPass will become famous soon enoughJoeyPass will become famous soon enough
Compressor Problem
We are using the new compressor and it has been cutting out intermittentantly. Simultaneously the status light would go out. Yesterday we isolated the PWM going into the spike relay as loose and once in a tighter fit both the light and compressor worked. Today at initial startup the compressor and ligh worked for about 5 seconds and then nothing from either. We replaced PWM's for both the spike and the relief valve, tried a different compressor, tried sample compressor code, tried a new spike...
Has anyone else had this problem or do you have any suggestions. '
Thanks in advance,
Unread 16-02-2011, 21:35
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Compressor Problem
Are you using a fuse in the spike or are you using a breaker?
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 16-02-2011, 21:51
We are using the black breaker in the spike.
Unread 16-02-2011, 21:53
We are using a black 20 amp breaker
Unread 17-02-2011, 08:10
Joey,
Are there any lights on the Spike? Try measuring the input voltage right at the Spike. It is possible you have a bad crimp or a wire has pulled out of the WAGO and you are not feeding the Spike.
Unread 17-02-2011, 08:54
fsgond's Avatar
fsgond fsgond is offline
Why aren't you throwing balls?!
AKA: Anthony
FRC #5484 (Memento Vitam)
fsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant future
We had this problem last year and it turn out to be a watch dog error. Although this was a very special circumstance, if everything else comes back working fine, look at the code. If you are worried that it is the breaker, replace it with a fuse, FOR TESTING ONLY. If you are pulling too much current the fuse will just blow.
Unread 17-02-2011, 09:05
Without a PWM cable, the Spike LED should always be on solid yellow if it's receiving 12v power from the Power Distribution Panel.
That tells you if it's powered properly.
