Go to Post I have yet to see an error where disabling the watchdog was the correct decision. - EricVanWyk [more]
Unread 02-16-2011, 10:36 PM
divixsoft's Avatar
divixsoft divixsoft is offline
FRC #0835
divixsoft is an unknown quantity at this point
Dashboard Help
You know the video stream panel of the dashboard, and how if you drag across the panel it make a rectangle and displays its coordinates on the bottom of the panel. Is there any way for the java program on the Crio to access those numbers? It there is how?
