Go to Post So we had forklifts in 2015 and now front end loaders in 2017. First has really embraced the industrial side of robotics. - dmorewood [more]
Unread 16-02-2011, 22:45
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Riveting the KOP Frame
Our team is currently working on cutting back on our weight. The andymark KOP frame has 32 nuts and 32 bolts holding it together and I am considering replacing them with bolts. We have we have 3/4inch long rivets so they do not go through the frame so I was considering using one on the top and bottom. How much of a problem would it be to rivet the frame together? Should we rivet them all, rivet half, or don't do it at all?
Any thoughts would be very welcome!
1058 PVC Pirates 2016 - xxxx
Unread 16-02-2011, 22:47
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
Re: Riveting the KOP Frame
think about emergency disassembly before you do anything, what would you need taken apart to service your robot?
Unread 16-02-2011, 22:49
AKA: Brendan Browne
In 3 years of FRC, the only time I have had to take apart a frame was last year and it was 80-20 and it was a very rare instance. We have nothing this year that would require it
Attached is a photo of the corners I am considering riveting:
Unread 16-02-2011, 22:50
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
we have riveted our entire frame before. It is a great option. You get a nice tight fit and you don't have to worry about nuts coming loose. Some folks on this board have bet they can drill out a rivet faster than you can remove a nut and bolt...
WileyB-J's Avatar
FRC #4976 (Rebels)
then its your judgement on that, rivets have been used on various robots ive seen and hold up. remember to bring a rivet gun + extra rivets just in case!
Unread 16-02-2011, 23:22
zbanks zbanks is offline
AKA: Zach Banks
FRC #0529 (Mansfield Hornets)
zbanks is an unknown quantity at this point
Send a message via AIM to zbanks
You say you're doing this to cut back on weight.
I'd first make check to see how much weight you'll actually save. You don't want to do all of that to save 0.1lbs.
Unread 16-02-2011, 23:28
AKA: Brendan Browne
The weight difference between two rivets and one bolt and a nut is noticeable and multiply that times 32 equals is significant. It is just the structural integrity that is my concern.
Unread 17-02-2011, 06:37
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
You will also have to add in the weight of gusset plates for each corner, and subtract the weight of those solid corner connectors. If your rivets don't go all the way through, they won't work with the corner connectors.
wilsonmw04's Avatar
Coach
We saved close to two pounds moving over to rivets one year. Again, the forces that these rivets will be under should not be an issue for your standard aluminum 1/4" rivet. We didn't have a failure because of wear, only improper installation.
Unread 17-02-2011, 08:12
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
We have been riveting for a few years now. No problems. And replacing the corner connectors with 1/8" plates will save alot of weight also.
Unread 17-02-2011, 12:16
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Brendan, I'd suggest making the switch to rivets if you can manufacture the 16+ L-shaped plates for each robot. I'm pretty sure you could expect to save ~2 pounds by swapping out all the bolts and funny connectors for little corner plates and rivets.
You know we've used rivets plenty of time with success on the IFI old KOP frame... I'm sure they'd work comparably well with gusset plates.
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 17-02-2011, 13:06
AKA: Brendan Browne
I know we have done it in the past with the IFI frame the Andymark frame is different which makes the riveting interesting/sketchy since the rivet cannot expand as much.
Thanks for all the suggestions!
Unread 17-02-2011, 14:15
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I would not try and rivet the KOP corner connectors, there is nothing there for the rivet to grab. If you want to go with rivets you'll want to make L or triangular plates to secure the corners and ditch the KOP connectors.
Unread 17-02-2011, 14:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
As many tall robots as there are this year, I expect we'll see lots of falling over...and if you are using the kit chassis and you have to lose 2 pounds, you might be better off trying to find two pounds that sits a lot higher off the ground, to go chasing after. That would let you lose the weight and keep the robot upright more often.
I love rivets, but the kit chassis is not really designed to be riveted together. As mentioned, if you make your own end brackets from flat aluminum and rivet them on you could achieve what you want. You can use the chassis as a drilling guide, too.
Good luck! sounds like you will have a busy next few days
Unread 17-02-2011, 15:12
Chris is me's Avatar
AKA: Pinecone
You can take two pounds out of those transmissions instead of riveting the chassis. I love rivets but you can't rivet those corner brackets.
