Go to Post One day the code will be written first, and then a robot built around it - dag0620 [more]
Unread 16-02-2011, 23:01
implosionprez's Avatar
implosionprez implosionprez is offline
AKA: Ty
FRC #2484 (Team Implosion)
implosionprez is an unknown quantity at this point
Connecting clyinders tip to tail
We are thinking that we want to connect two pneumatic cylinders, tip to tail. Can anyone direct us to the correctly sized fasteners to connect two 2 inch bore cylinders together in this fashion? Thanks!
Unread 17-02-2011, 01:48
AKA: Ty
Re: Connecting clyinders tip to tail
Is there such a thing as a connector we can buy (we don't have machining resources), to connect the tip of one 2" cylinder to the tail of another 2" cylinder?
Unread 17-02-2011, 01:57
AdamHeard's Avatar
Lead Mentor
The thread size on those is 1 1/4-12, and mcmaster has coupling nuts for them.
90565A355 should do it for you.
Unread 17-02-2011, 02:26
AKA: Ty
Is the 1 1/4-12 the thread size of the tail of the cylinder? What is the thread size of the tip of the cylinder?
Unread 17-02-2011, 02:40
AdamHeard's Avatar
Lead Mentor
Linking the tail end will result in a stronger connection, two large cylinders like that connected end to end creates a rather long beam.
Unread 17-02-2011, 02:46
AKA: Ty
Okay! Thank you very much. The thread size was exactly what I was looking for! (without actually knowing it beforehand)
Unread 17-02-2011, 13:20
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
An easy way is like we did back in 2008, notice the main arm cylinder is actually 2 cylinders end to end, we cut a couple plates out of 1/8" aluminum, drilled, and bolted them together making one solid cylinder piece with extensions out of both ends. This makes it VERY solid, preventing any movement at the joint. We are doing something similar with this year's arm.
Unread 17-02-2011, 14:33
craigcd's Avatar
craigcd craigcd is online now
FRC #2221 (RoboDawgs)
craigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant future
How well did that work? That is just too simple. That solves one of my problems with positioning.
Unread 17-02-2011, 14:36
Matt C's Avatar
FRC #1468 (J-Birds)
It worked well enough that we are using it again . . .
Just make sure the cylinders are butted (relatively) tightly together so they don't kick side to side at all.
(the main reason we did that in 2008 is that we couldn't use pistons that weren't on the approved "list". This allowed us to get the throw we wanted without going to a HUGE bore.)
