Go to Post As far as I am concerned, the quality of an electronic device is directly proportional to the number of blinky lights on it. - EricVanWyk [more]
Unread 17-02-2011, 07:57
Juggernaut's Avatar
Juggernaut Juggernaut is offline
AKA: Jeff
FRC #5404 (Gearaffes)
Juggernaut is an unknown quantity at this point
Viair 90 series compressor
I have seen a lot of threads this season about the 90 series compressors. Since the GDC is saying that they will not answer questions about specific components, I figured I would see if anyone here have more information about their legality.
The part that I am questionable about is that the maximum working pressure is only 120 PSI. R66 states that all pneumatic components must have a working pressure of at least 125psi. Does this mean we can not use these compressors?
Viair 92 specs
12-Volt
Permanent Magnetic Motor
Duty Cycle: 9% @ 100 PSI
Max. Working Pressure: 120 PSI
Amp Draw: 10 Amps
Inlet Filter Assembly Included
Inline Check Valve
Dimensions: 7.50" L x 2.10" W x 4.30" H
Net Weight: 2.50 lbs.
<R66> In addition to the items included in the KOP, pneumatic system items specifically permitted on 2011 FRC ROBOTS include the following items. All included items must be “off the shelf” COTS pneumatic devices rated by their manufacturers for working pressure of at least 125psi and burst pressure of 250psi, and used in their original, unaltered condition (except as required for assembly with other components).
Thanks for your time.
Unread 17-02-2011, 08:02
Electrical Engineer
Rookie Year: 1995
Re: Viair 90 series compressor
IMHO, yes, it would not be legal.
Mike Betts
As easy as 355/113...
Unread 17-02-2011, 08:15
Juggernaut's Avatar
AKA: Jeff
I just found a conflict in the rules. R66 says a working pressure of 125 while R69 says a working pressure of 120psi. I will have to post in the Q & A about this.
<R69> Compressed air for the pneumatic system on the ROBOT must be provided by one and only one compressor. This compressor may be either the compressor from the KOP, or an equivalent compressor that does not exceed any of the KOP compressor performance specifications (specifically: nominal 12v, 1.03 cfm flow rate, 120psi maximum working pressure). Compressed air shall not come from any other source. Off-board compressors must be controlled and powered by the ROBOT.
Unread 17-02-2011, 08:17
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
But the 90C, which is provided in rookie kits, has the same exact specs as the 92C. The only difference is the addition of an air filter assembly.
FRC78: 2010-Present
FRC121: 2002-2009
Unread 17-02-2011, 08:26
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Viair 90 series compressor
I can see why you question this rule. Look at the system as supply and load. On the supply side is the compressor should not exceed 125 psi. All components on the load side of the system must be rated for at least 125 psi, and the pneumatic lines cannot exceed a certain inside diameter. This guards against over pressurizing the system that can cause burst of a component. I believe you are right in questioning "least" being used for the compressor. I think you should ask the question, quote the rule and emphasize the word "least".
Does this rule mean that we can use a compressor that exceeds 125 psi?
I don't believe this is their intent, and the main regulator will keep the system below the max pressure. But think what happens if that regulator fails, and the compressor produces higher pressures than the components can handle. Nice catch!
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 17-02-2011, 08:45
Max intermittent pressure rating for the 90 series is 200psi.
120 psi maximum is what our robots are restricted to (by our properly set main regulator).
125 psi or greater is what the individual components have to be minimum rated for so we're sure they don't burst.
Our safety pressure relief valve vents excess pressure above 125psi.
The old compressors can exceed 125psi too.
Unread 17-02-2011, 09:18
Electrical Engineer
Rookie Year: 1995
This can be frustrating but you need to read <R66>:
The 92C was supplied in the KOP therefore it is legal regardless of the manufacturer's specifications. The 90C is being provided by you and you must provide documentation that it has a rated working pressure of at least 125 PSI.
Mike Betts
Unread 17-02-2011, 09:24
Electrical Engineer
Rookie Year: 1995
Originally Posted by Mark McLeod View Post
Max intermittent pressure rating for the 90 series is 200psi...
Mark,
I agree that, from an engineer's and mentor's perspective, it should be legal but, in order to get a uniform ruling by all inspectors at all events, someone needs to ask the GDC if a max intermittent pressure rating is sufficient to qualify under <R66> (working pressure of at least 125psi)...
Regards,
Mike
Mike Betts
Unread 17-02-2011, 12:15
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
The GDC ruling was that a compressor of identical specs may be used in place of the 090C, since the 092C and 095C only differ in their use of an external filter or a different bracket they are fine. If you are worried about passing inspection go to Viar's website and do a screen print of the spec page for the 090C and the the one you are using.
Unread 17-02-2011, 12:52
Here's the rule that applies.
Unread 17-02-2011, 13:24
Mr V's Avatar
FRC #5588 (Reign)
Here is the page for the KOP 090C compressor
http://www.viaircorp.com/OnRoad/90C.html
The 092C
http://www.viaircorp.com/OnRoad/92C.html
And the 095C
http://www.viaircorp.com/OnRoad/95C.html
Unread 17-02-2011, 15:14
Juggernaut's Avatar
AKA: Jeff
The problem I have now is that technically, neither the 90C or 92C compressors actually are in compliance with R66.
The working pressure of the compressors is 120psi and the only rating I found for the burst pressure was 200psi.
