Go to Post dang. I wish my legs were as good as Dave's. - Amanda Morrison [more]
Unread 16-02-2011, 22:15
arithehun arithehun is offline
AKA: Ari Falkner
FRC #3024
arithehun is an unknown quantity at this point
Jaguar vs Vector
So, in our LabView project, we had a PVM channel hooked up to a jaguar, which was hooked up to a motor. It's speed was controlled by the y-axis of a joystick, and activated by pressing a button. This all worked fine, but for hardware issues, our team leader changed the jaguar to a victor. I have not changed anything except changing the PVM driver from a jaguar sensor to a victor sensor, but now it does not work.
Any ideas?
Unread 16-02-2011, 22:26
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: Jaguar vs Vector
What sort of feedback are you getting from the Victor (ie from the LED)?
Are you sure that the Victor is working properly? Have you tried a different Victor?
Team 2052- KnightKrawler
Mentor and volunteer
Unread 16-02-2011, 22:31
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
IF i remember correctly, in previous years you had to choose between a Victor and a Jag in LV. Is this still accurate?
Unread 16-02-2011, 22:35
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
yes, in begin.vi, you need to switch the motor setting from jaguar to victor.
Unread 16-02-2011, 22:41
Victors are notoriously tricky to plug the PWM connector into reliably. Make sure you get it properly seated.
Unread 16-02-2011, 22:55
Wolfgang Wolfgang is offline
AKA: Mehmed
FRC #1245 (Shazbots)
Wolfgang is an unknown quantity at this point
The good news is that victors seem to be far more reliable.
The biggest difference between the two is that victors control speed mechanically while jaguars control it electrically.
Additionally, jaguars are a lot bigger than victors.
Unread 16-02-2011, 23:34
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
I know in the programming if you don't have a jaguar hooked up to a port registered as a jag it can cause all sorts of issues. I would change the jag to a victor in programming too...
Unread 17-02-2011, 03:49
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
What does this mean?
mechanically?
There are no mechanical parts in a victor or jaguar, besides the fans.
-Borna Emami
Team 0x27
Unread 17-02-2011, 10:42
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
I think this is VERY debatable. There are advantages and disadvantages to each device. I do not know the exact statistics for my current team, but for my prior team I believe we were pretty much dead even for reliability* between Jaguar's and Victor's.
*Reliability also increases considerably when installed and powered correctly according to manufacturer specifications.
Unread 17-02-2011, 10:49
Victors create far more ripple current in the motor, which means the motor gets hotter compared to a Jaguar-driven motor with the same torque output.
Unread 17-02-2011, 10:59
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Program in LV must match the parts you have on the robot.
Both Victors and Jaguars work. We've experienced the same number of failures with both, but more reliability with Victors--we used 4 jaguars on one robot, and one of them died at a post-season demo. We've used 4 to 6 victors on our other 4 robots, and had one bad out of the box, and never any other failures.
Neither one has what I would consider sufficient markings on the terminals to prevent miswiring. These parts are used by students who often have little knowledge of the importance of wiring stuff up properly, and the implications of miswiring--they should have highly legible markings to help the user figure out instantly which terminal is positive, which is negative, and which side the motor connects to. The little painted screws don't help at all if you have to remove them to install the wires!
