Go to Post its pretty great when non FIRST friends go into your purse for chapstick or something and find a spike... - anna~marie [more]
Unread 12-02-2011, 10:55
mattiej's Avatar
mattiej mattiej is offline
Programmer Guy
FRC #3413 (Mad Cows)
mattiej is an unknown quantity at this point
Problem with wireless
I seem to be having a problem with the d-link when I connect wireless, but not when directly wired. I plugged into the d-link (in ap mode) with an Ethernet cable, I was able to configure it's settings. I then changed the LAN ip to connect to the new settings (10.34.13.1 on the router, 10.34.13.51 on my computer). I was able to connect like that. I ran into a problem when I tried to connect wireless though. When I connected wirelessly, I changed my computer LAN address back to default, and changed my wireless ip on adapter 1 to 10.34.13.51. When I connect, it takes a while to connect and then tells me I have limited connectivity. Originally the driver station would say no robot communication and two lights on diagnostic (DS Radio and Bridge) would flash alternatively. When I tried to navigate to the settings page on the d-link, I couldn't connect. Help?
Man pretending to be interested: "So how does this robot of yours work?"
Me tired of man pretending to be interested: "Magic. And Purple Yetis."
Unread 12-02-2011, 12:02
Team 1574's Avatar
Team 1574 Team 1574 is offline
FRC #1574
Team 1574 is an unknown quantity at this point
Smile Re: Problem with wireless
Hi team 3413!
We have the same problem with the d-link AP.
we tried everything and it seems that the wireless of the D-link can't communicate with anything, but if i connect it direct to the laptop with a cable i have no problems to communicate.
If you got a solutions please send me in the mail.
asafis@walla.com
Thanks a lot,
Asaf - Team 1574
Unread 12-02-2011, 18:21
When Windows tells you "limited connectivity", it just means it doesn't find a connection to the internet.
Unread 12-02-2011, 20:25
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
If you're able to use a hardwire connection, but the same settings don't work over wireless, I'd start to suspect you either didn't set the radio band properly (for 99% of computers, you'll need 2.4GHz mode) and/or you've enabled some kind of MAC filter on the wireless access by accident.
Can you actually see the wireless access point? Try changing the name a few times and make sure the computer sees the different network SSIDs to confirm you're in the right radio band.
Matt Krass
Unread 17-02-2011, 10:42
mattiej's Avatar
Programmer Guy
So far none of these solutions have worked. I understand that limited connectivity means that it doesn't connect to the internet, but I was just posting it in case it affected something. I can see the wireless accsess point. I've changed the name and I can see each different one. I've also reset the router and went by the instructions directly as listed on the radio pdf, and it still does not work. I tried connecting with the classmate from last year, and it got connection. The problem is our reimaging flash drive does not work so I cannot get the 2011 software on it. What can I do to get my personal computer to connect with the robot?
Unread 17-02-2011, 12:33
You don't need the Kit reimaging flash drive to get the new software on your old Classmate.
That Kit flash drive only gives you Windows 7, if you want it.
This year's software comes from the Kit LabVIEW or WindRiver DVDs and the online Software Updates.
You can install them all via any generic thumb drive just like you do for your own laptop.
Unread 17-02-2011, 12:46
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
reset the router
Are you referring to the router that we have received in the past years (i.e. not this year)? If so, you cannot use a router along with the DLink in AP Mode. You can use the router if you configure it with the DLink in Bridge Mode. But good luck to this, there has been no official documentation on this procedure and although it is a fairly simple process I have not heard of any teams doing this.
We were using last year's router as a connection for our programming team to our SVN Server. As that router's SSID is "1208" and the DLink's SSID is "1208" if the router is turned on we cannot connect to the DLink with our Classmate. There is obviously a solution to this to enable both functions to work, but the simplest was just to turn off the router when we were using the robot, as we only needed to access the SVN Server at the start and end of the day for backing up software.
Unread 17-02-2011, 20:52
mutantblond mutantblond is offline
FRC #2523
mutantblond is an unknown quantity at this point
if I understand you correctly, you're saying that we don't need to use the router to communicate with the Dlink with our Classmate. We can communicate wirelessly from the Classmate to the Dlink (can ping it and http to 10.25.23.1), but when we run the driver's station, we never get communication with the robot. the Dlink is connected to LAN port 1 of the Crio, the Dlink is set on AP, and the security has been disabled.
any help would be appreciated!
elaine
Unread 17-02-2011, 21:29
DavidGitz's Avatar
Yes that is exactly correct. You should not be using the router. Make sure it is turned off. We had issues where the router would be mistakenly turned on without the programming team's notice and spent about an hour of troubleshooting before we caught this. This has actually happened 3 times.
Can you ping 10.25.23.2? That is the address of the cRIO. If you can, the the issue is with the Driver Station. If you can't, there is another problem (such as a firmware issue). Make sure you set your team number on the DS. If this doesn't work, a fix that we used was to set the connection in the developer mode, and then in the driver mode set it to use a manually configured connection.
Unread 18-02-2011, 17:51
lonski lonski is offline
FRC #2486
lonski is an unknown quantity at this point
Hello this is the programmers from team 2486 we are having trouble with the wireless bridge. the spikes and solenoids we are using start to turn on and off while we are connected to the d-link, and it doesnt matter where we have the bridge. when we use the wireless from last years system everything works fine. so does annyone know what is going on with the wireless bridge.
Unread 18-02-2011, 18:01
FRC #2486
we are also having the jaguars going crazy too while connected to the d-link
Unread 18-02-2011, 20:34
FRC #2486
Hello teams. team 2486 found that the wireless bridge has issues communicating with windows vista. the bridge communicates with windows 7 properly. we dont know about other opperating systems.
Unread 19-02-2011, 10:37
sometimestommy's Avatar
sometimestommy sometimestommy is offline
Schrödinger's Assistant
AKA: Thomas Moll
FRC #1939 (Ku-Nig-Its)
sometimestommy is on a distinguished road
Hello, I'm from team 1939. We have had the same problem this year and I was wondering if anyone could clarify the network setup that I will crudely try to recreate
Is it cRio-->dlink (new router)---->Classmate---->driver station software
Or is it. cRio-->dlink (new router)--->old router ( configured for last year)----> then so on
Unread 19-02-2011, 11:05
This one.
Unread 19-02-2011, 11:06
cRio-->dlink (new router)---->Classmate & driver station software
