Go to Post Then use Newton's handy-dandy 2nd law (Force = mass*acceleration) to solve... - Chris Hibner [more]
Unread 15-02-2011, 20:06
Pmaxm00 Pmaxm00 is offline
Lead Programmer
FRC #2974 (Team WALT)
Pmaxm00 has a spectacular aura aboutPmaxm00 has a spectacular aura about
Unhappy Setting Up Secondary Driverstation
Okay, I have been having trouble for the past 4 weeks on setting up our secondary netbook. I have netbeans 6.9.1 and all plugins installed. I have the driverstation software installed, along with all .dll files and everything needed. When I try to compile and build that code, I get a "java.net.ConnectException: Connection timed out: connect" error. We are using a HP Mini 110-3000, using Windows 7 Home Premium. Any help would be useful.
Impossibility? I accept your challenge.
Unread 16-02-2011, 00:57
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Setting Up Secondary Driverstation
Check your ip: it should be 10.29.74.6 and subnet should be 255.0.0.0
Unread 16-02-2011, 13:52
Lead Programmer
Ipv4 or Ipv6? What should the default gateway be? And what about the DNS server addresses?
Unread 16-02-2011, 14:52
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Should be IPV4 we disabled IPV6,
DNS server leave it blank.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 17-02-2011, 10:48
pfosx's Avatar
pfosx pfosx is offline
AKA: Paul Fossenier
FRC #3161 (Tronic Titans)
pfosx is an unknown quantity at this point
make sure you've disabled windows firewall.
Dean's List Finalist Award - WAT 2011
