Go to Post Stacking totes on end; Gives you extra height, alas; Topples with a sneeze. - BethMo [more]
Unread 17-02-2011, 14:05
Re: Driver Station Errors
Watchdog Expiration: System 1, User 0
Don't worry about this one unless you get a lot of them. One is normal for changing robot modes: Disabled, Teleop, Autonomous
ERROR <Code> -44061
This means your Teleop loop might be running too slowly.
It means you aren't calling Arcade or Tank Drive quickly enough.
ERROR <Code> -44003
Is if the camera is not connected or if it's still booting when the cRIO tries to talk to it.
ERROR <Code> -44027
Means you used one of the DIO's twice.
Probably just left one of your Opens with the default DIO 1 and it conflicted with something else you Opened using that same DIO.
