Go to Post Coming to MTV this fall: Pimp my Segway - Francis-134 [more]
Unread 17-02-2011, 08:29
AnimeOtako's Avatar
AnimeOtako AnimeOtako is offline
FRC #3475
AnimeOtako is an unknown quantity at this point
Exclamation How do we get the spike in both directions in labview?
Yeah,we are from team 3475,we're also rookies and we have no idea how to make the spike relay go in both directions. Well what I mean is that when we program it to go one direction it doesn't go in the other, all we are getting are jolts from the window motors we are using.
Please if there is any one that can help please reply, we are in desperate need.
Sincerely team 3475 programmer,
Takeshita Green
Unread 17-02-2011, 08:35
Re: How do we get the spike in both directions in labview?
Assuming you are talking about running the motor off a Spike relay.
Use the Relay Set enumerated input:
  • Forward - one direction
  • Reverse - the opposite direction
  • Off - stop moving
Unread 17-02-2011, 09:33
AnimeOtako's Avatar
FRC #3475
Yes we have already done that and the problem still continues. We have checked our teleop vi many times and have tried different things to get both reverse and forward reactions,but it still continues to go in one direction.
Could the problem be a default setting somewhere in the programming?
Unread 17-02-2011, 10:19
It's easy to tell if it's programming vs electrical in nature.
There are Relay status LEDs (a red/green for each Relay) on the Digital Sidecar that tell you exactly what the code is commanding.
It doesn't matter if the Spike is attached or not.
If your code is working correctly to command Forward and Reverse, then the Relay LED for the proper Relay will show:
  • Off = both LEDs off (dark)
  • On = both LEDs on (red & green), not used for motors
  • Forward = green LED lit
  • Reverse = red LED lit
Unread 17-02-2011, 10:23
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
If you have isolated it to a programming issue can you post your code?
Unread 17-02-2011, 14:22
AnimeOtako's Avatar
FRC #3475
Yes I am aware about the led light signals on the digital sidecar but even so when one light is constant the other one flickers on and off constantly and will every once in a while the motor will react in reverse.
Unread 17-02-2011, 14:26
...when one light is constant the other one flickers on and off constantly and will every once in a while the motor will react in reverse.
That sounds very much like your programming is trying to do two contradictory things at the same time. It's time for you to show us your code so we can point out where it can be improved.
Unread 17-02-2011, 18:19
AnimeOtako's Avatar
FRC #3475
Unread 17-02-2011, 21:12
AnimeOtako's Avatar
FRC #3475
[IMG]http:/team358.org/files/.../Pneumatics-StepByStep-cRIOversion.doc[/IMG]Yeah here are three images of our Begin, Teleop, Finish VIs
Unread 17-02-2011, 21:47
That example is for a pneumatic single solenoid connected via a Relay, not for a motor.
Unread 18-02-2011, 05:42
AnimeOtako's Avatar
FRC #3475
Then how would we do it for a motor because I don't have anything else to base the programing off of.
Unread 18-02-2011, 06:45
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Look at Team 358's page for helpful examples: http://team358.org/files/programming...2009-/LabVIEW/
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 18-02-2011, 07:20
Daiane's Avatar
Daiane Daiane is offline
AKA: Daiane Rodrigues
FRC #1772 (Heitortec Trail Blazers)
Daiane will become famous soon enoughDaiane will become famous soon enough
Send a message via MSN to Daiane
Hi,
I'm with problems in my labview program.
The tank drive and the compressor run normally, but the relay and the solenoid is not running.
Can you help me, part of my program is below.
ID:	10194  Click image for larger version
ID:	10195  Click image for larger version
Unread 18-02-2011, 08:24
Jon236's Avatar
AKA: Jon Mittelman
In Teleop, you have spelled the ref nums for the solenoids differently (first letter not capitalized).
Jon Mittelman
Unread 18-02-2011, 08:34
DavidGitz's Avatar
Also,
-The Compressor requires a Digital Input for the Pressure Switch.
-The Set Relay for "braco" requires an enumerated constant, not a number. Enumerated constants evaluate to numbers but this is bad practice. This is why you see the red dot on the Set Relay, the .vi is basically doing implicit datatyping, i.e. it sees a datatype it doesn't expect but it can deal with it.
-I don't know what the purpose of your solenoids is, but if these go to a single double-acting solenoid then you have the possibility of both being turned on at the same time, which is probably not what you want. Instead, you could put both Solenoid Sets in your case statement.
