Go to Post What can you do? The more time you waste here speculating the less time you have to work on the robot. Go! Build Robots! Now! - Jessica Boucher [more]
Unread 17-02-2011, 14:29
C_Tenranma's Avatar
C_Tenranma C_Tenranma is offline
Programmer
AKA: Chelsea
FRC #1865 (RoboBuffs)
C_Tenranma is an unknown quantity at this point
Robot Code will not stay...
We have just about everything running for our robot. However, the robot code from labview will not stay (cannot properly explain it)...
Everytime we discconect/turn off the robot, we have to re-run the robot code as compared to last year's robot, we just had to turn on the robot and the code would start up automatically...
So, any suggestions? Any help would be much appreciated...
Unread 17-02-2011, 14:31
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: Robot Code will not stay...
If I remember correctly, there is a setting (checkbox that says "Run Deployed Code at startup") when you image your cRIO for LV that checks to keep it, not just run it while the robot is on.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 17-02-2011, 14:35
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
You have to tell the robot to run the code as startup.
When you first open your project folders.
Expand the build specifications box down at the bottom of the list. Right click on FRC robot bootup deployment and select build.
Once that is done right click again and select run as startup.
That way the code should run when you first turn on your cRio.
Hope this helps.
Edoga
Unread 17-02-2011, 15:23
Make sure the "NO APP" switch on the cRIO is turned off.
