Go to Post I love you ChiefDelphi times! - Amanda Morrison [more]
Unread 17-02-2011, 15:56
BaronRobotics BaronRobotics is offline
FRC #1413
BaronRobotics is an unknown quantity at this point
Wireless Setup Problems (PLEASE HELP!!!)
I am from team 1413 and we are currently in the process of setting up our wireless connection between the Classmate and Bridge. Our code works and robot functions perfectly when directly wired. We have reset the bridge and reconfigured everything. Our Classmate will not detect the wireless connection. We are in a predicament where no one really knows where to go from here. If anyone has encountered the same problems and has overcome them or if anyone just knows the solution, our team would greatly appreciate the assistance. Thank You!
Unread 17-02-2011, 16:06
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: Wireless Setup Problems (PLEASE HELP!!!)
If it's in bridge mode, you cannot connect to it wirelessly right now. Use AP mode. Bridge mode is for competition only.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 17-02-2011, 16:09
mattiej's Avatar
mattiej mattiej is offline
Programmer Guy
FRC #3413 (Mad Cows)
mattiej is an unknown quantity at this point
We had a somewhat similar problem at first. From what you are saying, it sounds like the problem could be one of three things:
1. You have the d-link set to bridge or auto mode. On the switch in the back, check to make sure it is set to AP mode. This is for working on the robot at home. It will be set to bridge at the competition.
2. Your 802.11 Band (d-link) is set to 5.0 ghz. Check and make sure it is set to 2.4 ghz.
3. Check the ip of your computer. it should be 10.14.13.9 or higher. I generally keep mine at 10.xx.yy.51 .
Man pretending to be interested: "So how does this robot of yours work?"
Me tired of man pretending to be interested: "Magic. And Purple Yetis."
Unread 17-02-2011, 16:56
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
I have a question related to the d-link in bridge mode. What, if anything, will we need to change on the Classmate for competition? I know the d-link will be reset for bridge mode, but do we need to change any of the IP addresses in order to connect to the competition router, and if we do, what should they be?
Unread 17-02-2011, 17:52
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
You should not have to do anything other than make sure your switch is in bridge mode.
