Go to Post You can't expect a situation to get better if you don't make an attempt to confront it. - AndyB [more]
Unread 17-02-2011, 16:07
oceanblack's Avatar
oceanblack oceanblack is offline
FRC #3396 (Imperium Machinamentum)
oceanblack is an unknown quantity at this point
Jaguar Motor Control
Hello ChiefDelphi! I hope everyones robots are going well.
My team is currently working on their arm and it's my first year programming so I'm in a bit of an issue.
I have a few questions about Jaguar Motor Control using Labview. We have the default sample modified and up and running and the robot is moving great. We have 4 motor controllers opened using the [DRIVE] Open 4 Motor box. However, we have a bit of slack on one chain and I was wondering if it was possible to offset the amount of information is sent to some of the motors (so like multiply it by 0.9 to make the one side move a bit slower)
How do I modify values sent to Arcade Drive for individual motors?. So far example, I have x * 0.9 sent to the left motors, and x sent to the right motors.
The other issue is we are using Jaguar motor controllers to control the movement of the arm. However, each motor controller is controlling a single motor. In labview, I noticed the open function requires 2 motors, or does it? Maybe someone can get me some help. But I'm trying to send individual values to each motor controller and I'm wondering if I have to supply 2 motors or can I just use one...
Unread 17-02-2011, 21:36
Re: Jaguar Motor Control
Slack in the chain won't cause a side to travel slower, unless you have so much slack that it's skipping teeth. If that's the case, you really need to fix the mechanical problem.
For a mechanism other then a drive train, use the MotorControl VIs rather then RobotDrive.
Unread 18-02-2011, 15:15
oceanblack's Avatar
Thanks for your response. We've tried the MotorControl via, and I've tried setting the output to different double values (0.1, 0.2, 0.8, 1) etc, but none of these affect the actual speed of the motor...
Also, there is a slack in the chain and we can't fix it mechanically because the of the layout of the gearboxes (when you flip them the chain gear is on the other side). Isn't there a way to fix this via software (IE, adjusting the value for each motor controller?)
Unread 22-02-2011, 17:39
I think it would help if you would define the problem a bit more clearly because it sounds like you want to fix the slack in the chain in software. That can't be what you are saying, is it?
Unread 23-02-2011, 17:45
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Clayton Yocom will become famous soon enoughClayton Yocom will become famous soon enough
Send a message via AIM to Clayton Yocom Send a message via MSN to Clayton Yocom Send a message via Yahoo to Clayton Yocom
If this didn't change anything no code can fix your problem. Make sure when you used MotorControl correctly, and Opened a motor in begin and closed it in finish and didn't have any conflicting PWMs with a motor in a RobotDrive open. RobotDrive is supposed to make programming a drive base easier, but is very convention over configuration. If you don't like the convention, then you'll have to go somewhere else I believe.
Unread 19-02-2011, 21:57
MattCarey3625's Avatar
MattCarey3625 MattCarey3625 is offline
#3625 Programming and Wiring Head
FRC #3625 (Some Assembly Required)
MattCarey3625 is an unknown quantity at this point
Ok, it is possible to do this but you will not be using the Arcade Drive. You need to check the values and while the value of a joystick axis is over a certain number you need to begin to take away from the motor output. So you need to read info from 2 axises; 1 for speed and the other to sense when the speed needs to be reduced so you would use "While Axis 1 > 0.2 or Axis 1 <-0.3 (Axis 2 - Axis 1)... This is rather hard to explain through text, but you need to create an algorithm for deprecation of motor speed and a float system so you dont take away speed imediatley. Good luck!
matt@hp-mini-110$> sudo make robot
sudo pass for matt:
unable to make robot
Unread 22-02-2011, 14:47
oceanblack's Avatar
I'm confused. Is there no way to simply adjust the values for each individual motor.
Unread 23-02-2011, 10:45
The easiest way is to simply adjust the joystick commands before they enter the Tank/Arcade/Holonomic Drive.
For instance, multiple one joystick by .9 to reduce it to 90% of the power of the other joystick in Tank Drive.
If you want full control of individual motors, then you have to declare them as individual motors and setup your own drive logic, rather than using Open 2/4 Motor or Tank/Arcade/Holonomic Drive.
