Go to Post Quitting FIRST was so hard that I felt like I needed a 12 steps program to help me through it. - Ken Leung [more]
Unread 17-02-2011, 16:20
Howard1502 Howard1502 is offline
FRC #1502 (Technical Difficulties)
Team Role: CAD
Howard1502 is an unknown quantity at this point
Re: Constraint Problem
Originally Posted by inventor_phild View Post
Duke461,
Good suugestions. Howard, any further problems I can have a look at the file and provide a solution.
Thank you for the suggestions Duke, I really appreciate them! But I'm still having the problem of constraining.
"inventor_phild", if you would be willing to help me out if I sent you the file, that would be greatly appreciated also! Just let me know how/where to send the file to and I would be very happy if you'd help me with this problem I am having.
Thanks!
Howard
Unread 17-02-2011, 16:28
0zymandias 0zymandias is offline
FRC #1712
0zymandias is an unknown quantity at this point
Are you sure the bottom of the part is actually flat? Did you CAD it yourself? I know I spent way more time than I'd have liked last year trying to constrain a part that wasn't made in a CAD program and just wasn't quite straight. Have you tried constraining from the origin planes of the object rather than the faces?
Unread 17-02-2011, 17:13
Team Role: CAD
I did not CAD it by myself, but I have tried work planes, regular planes, original planes, etc. I have tried many things, but it just doesn't seem to be working. It seems like I'm missing something simple, because I feel it shouldn't be this difficult.
Thanks anyways!
Howard
Unread 19-02-2011, 21:23
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Attach the files here - I guarantee there is a problem with the parts. (or you've zoomed in beyond the capabilities of you graphics card.) My bet is on a problem with the parts.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 23-02-2011, 18:15
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Howard,
If you attach the files there are a couple of us who will look at the issue.
You can also email me the files at,
phil.dollan@autodesk.com
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
