Go to Post A well-designed shifting transmission, controlled by an experienced driver (or a clever bit of software), is an advantage. - Alan Anderson [more]
Unread 07-11-2002, 12:54
Matt Reiland's Avatar
'The' drive behind the drive
Do a quick search of the forums, it will bring up many threads.
The pressure switch is a digital input that should be shown how to wire a digital input in the manual for the control system, you can pick the input. We had no pnuematics last year but I think it was adjustable for the pressure that will trip it. Then you can Turn on/off the compressor based on the switch or two switches (one for high, one for low) I think there are also a few white papers on Compressor programming
Check this white paper on the sixth page of white papers for an example
Description:
Pneumatic Wiring and Programming
originally submitted: 01.18.2001
by Dan Grostick
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
Communications via the Programming Port Larry Barello Technical Discussion 9 10-06-2003 23:33
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
pbasic programming punarhero Programming 4 21-01-2002 23:32
