Go to Post Free food attracts us like flies. It's the one sure way to get us to meetings. - Mark McLeod [more]
Unread 17-02-2011, 16:34
MisterL's Avatar
MisterL MisterL is offline
Robot C Master and Mentor
AKA: Derrick Canfield
FRC #1544 (One Byte Short)
MisterL is an unknown quantity at this point
Question Solenoid Pneumatics Help
How can we control bimbas with precise control? Not just all the way open or all the way closed?
"Doing Java from scratch with no previous experience with it? Piece of cake!" Famous Last Words
One Byte Short Mentor
Unread 17-02-2011, 22:10
Electrical Engineer
Rookie Year: 1995
Re: Solenoid Pneumatics Help
Under the current rules and in light of some of the GDC's responses to pointed questions on the subject, you can't.
JMHO...
Mike Betts
As easy as 355/113...
Unread 17-02-2011, 22:42
QRohlf's Avatar
QRohlf QRohlf is offline
FRC #1823 (PING)
QRohlf is an unknown quantity at this point
Pneumatics are limited by the elementary gas law that states that a gas will fill its container. Meaning that you really can't physically have any more control than all the way in or all the way out on a standard pneumatic line cylinder.
There are some workarounds, however. While you cannot directly control the volume of gas present in the cylinder, you can control the pressure of the gas in the cylinder. This means that if there is enough resistance against the cylinder, it won't open all the way at low pressures. You *might* be able to accomplish this by either rigging both a full-presure (60psi) line and a line that's been regulated down to half-pressure (or less) to a T attached to the cylinder, then activating one of the two lines for position control, or by pulsing the pneumatic reed switch very quickly so that the cylinder isn't fully pressurized before the reed switch shuts off the flow.
I have never tried either of these methods, and I doubt either of them would work terribly well.
As an alternative, Bimba does sell 3-position and electronically positioned specialty cylinders. I've never used these and don't know about usage or cost, though.
