Go to Post Copies gonna copy. - Arpan [more]
Unread 17-02-2011, 10:17
Tds123's Avatar
Tds123 Tds123 is offline
There is no I in team =]
AKA: Timothy Shub
FRC #1396 (Pyrobots)
Tds123 is an unknown quantity at this point
Send a message via AIM to Tds123
Line Sensor programming help
Can someone please give me an example of how the line sensors should work? How do i make the robot follow the refllectix tape using the line sensor .. I have it hooked up correctly because i programmed the dashboard to read when it has seen the refletix tap
ThE sCaLeS oF bAlAnCe (Team 1396)
Unread 17-02-2011, 10:52
Re: Line Sensor programming help
The line on the carpet is not made of the expensive retroreflective material. It is 2-inch-wide gray gaffer's tape.
The easiest way to follow a line is to have two sensors not quite as far apart as the tape is wide. When neither sees the tape, turn right. When the right one sees the tape, go straight. When the left one sees the tape, turn left. If you want to detect the end-of-line mark, use a third sensor to the left of the others. When all three see the tape, stop. This will follow the left edge of the line. It should be obvious how to change it to follow the right edge if you want to.
Unread 17-02-2011, 16:38
Tds123's Avatar
AKA: Timothy Shub
i was actually kind of hoping for a little demo program on how to move the robot if the sensor sees the tap
Unread 17-02-2011, 16:48
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
there is a line following demo in the demo projects that come installed with the WindRiver Workbench
