Go to Post "It's not a flashlight! it's an arduino with a really strong status LED!" - Leav [more]
Unread 17-02-2011, 16:52
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
Encoders
What will encoders do, how will they help us in teleop, and how do i program them?
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
Unread 17-02-2011, 17:03
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Encoders
Encoders measure the rotation of an axle. You can put them on your drive wheels and they will measure how far you have turned the wheels. Some encoders (called quadrature encoders) are able to give you direction of rotation while other are just able to tell you that the shaft has turned. With that information you can figure out how fast your wheels are spinning by determining how much they have rotated during a certain time interval.
During teleop it is possible to use them to control the velocity of your wheels using a control loop (like a PID controller) this will allow you to ensure that all of your wheels are spinning at the correct speed. You could also travel a certain distance or determine if your wheels are spinning at different rates and correct that to help you keep your robot strait. You could also use them on an arm(though a potentiometer might be better) or a lift so that you could know what position they are in during teleop.
How to program them is more complicated because I don't know what language you are using but WPILIB has built in support for encoders, so you should be able to get readings rather quickly with any language.
Unread 17-02-2011, 17:11
Re: Encoders
labview is what i am programming them in, hence me posting it in the labview forum.
Unread 18-02-2011, 09:13
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Re: Encoders
For programming (and physical wiring) you can look at examples. From the LabVIEW Getting Started Window click on Find FRC Examples...
Doug Norman
Unread 18-02-2011, 16:12
Re: Encoders
I can't find any examples of encoder programs, i would love it if someone could send me an example.
Unread 19-02-2011, 15:10
Baconfly Baconfly is offline
AKA: Tylor
FRC #3330
Baconfly is an unknown quantity at this point
Re: Encoders
If you go down to find FRC Examples on the mainpage of the LabVIEW program there is an example there.
