Go to Post Thou Shalt Not Leave Crap In The Walking Path. - Billfred [more]
Unread 17-02-2011, 17:23
Wicked Wicked is offline
FRC #0354 (G-House Pirates)
Wicked is an unknown quantity at this point
Vision processing
We want to have the robot align itself with one pole, drive forward until it reaches the pole, and then hang the ubertube.
I've been looking through the 2011 Vision Example VI. It seems to have the necessary data for this (locations of the targets and the poles), but I'm not sure how to use it to control the motors.
How exactly could we do this?
Unread 17-02-2011, 21:56
Re: Vision processing
If you know the location in the camera image of the pole you want to reach, and you know the location of "straight ahead" on the robot, you can compute the angle the robot needs to turn in order to aim for that pole.
If you know the height of the target in the camera image, you can compute the distance to the target using some simple trigonometry.
Use the turn angle and the drive distance to derive inputs to an Arcade Drive function.
Unread 18-02-2011, 15:52
We were actually thinking of using strafing to align with the pole.
Can you elaborate on "simple trigonometry"?
Unread 18-02-2011, 16:16
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
You could use a PID to strafe and line yourself up horizontally with the pole.
  1. Mount your camera such that the center of the image is "straight ahead" for the robot.
  2. If you can see the end of the peg you want to hang on in your image, make the distance between that and the center of your image equal to the error.
  3. Strafe in the correct direction until the error is zero!
As far as stopping at the right forward position. You can use a triangulation method like Alan said. If you don't want to calculate anything, just see what vertical height of the target in your image corresponds to the forward position you are looking for. Set up a PID for that as well with the setpoint equal to that vertical position in your image.
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 18-02-2011, 17:26
Okay, I think I have a basic idea of what needs to be done.
But another question: How could we get the example vision code into the FRC framework? Does it go into VisionProcessing.vi, RobotMain.vi, or somewhere else in the code?
Unread 18-02-2011, 22:03
Vision Processing sounds like a good place. And to share results, write the results to a global variable or two. Make the driving code read from the globals.
Greg McKaskle
Unread 15-01-2012, 21:51
Lawlhwut Lawlhwut is offline
None #2853
Lawlhwut is an unknown quantity at this point
So how would one connect 2 axis cameras to the robot? The CRIO only comes with 1 ethernet port for the camera.
Unread 15-01-2012, 21:53
The ethernet port is actually to plug into the dlink switch. The switch allows you to plug in other enet devices such as the camera(s).
Greg McKaskle
Unread 15-01-2012, 22:04
None #2853
I thought the images from the camera had to be processed by the CRIO before being sent to the computer? Or am I gravely incorrect? If you're right, is the number of ports on the router the only limitting factor for adding additional cameras?
Unread 15-01-2012, 22:19
The camera runs a web server. It can handle connections from up to five computers at once. The DLink has room for all sorts of enet devices including cameras. If the rules don't prohibit it, you could stick another switch on the robot and connect even more devices.
Greg McKaskle
Unread 15-01-2012, 22:23
None #2853
Thanks for your help. Really appreciate it.
