Go to Post Once I see that it is black with aluminum ends, I only care about the inside. Sort of like Oreo's. - Al Skierkiewicz [more]
Unread 17-02-2011, 17:34
Exernie Exernie is offline
FRC #3080
Exernie is an unknown quantity at this point
Exclamation Too Much Code??
When i write the code, for example a 4 wheel drive system and i build and run it works through the driver station. but when i add to the code, say for example a motor, nothing works. but when i make a code only for that motor, it works. i just can't get them together. Help? could it be the classmate being stupid?
ps. the driver station says one loop could be starving another.
Unread 17-02-2011, 17:44
Wicked Wicked is offline
FRC #0354 (G-House Pirates)
Wicked is an unknown quantity at this point
Re: Too Much Code?
Can you post a screencap of your code, so we can get a better idea of what the problem is?
Unread 17-02-2011, 18:03
FRC #3080
Re: Too Much Code??
<a href="http://tinypic.com?ref=24o5ca9" target="_blank"><img src="http://i51.tinypic.com/24o5ca9.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com?ref=i4imxi" target="_blank"><img src="http://i51.tinypic.com/i4imxi.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Unread 18-02-2011, 00:58
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Too Much Code??
Didn't you post this in another thread also?
Anyway, one problem is that you have two robot drives. The robot drive vi is only meant for the wheels. For other motors (like on your arm, or your claw), you want to use the normal "motorcontrol" vi (it's under actuators).
You open it in begin the same way you would for the robot drive motors. In teleop, you just wire the joystick value to it and it's golden.
Unread 18-02-2011, 06:38
Re: Too Much Code??
Correction, there are actually three robot drives. I can't think if a reason why you can't have multiple, but if nothing else, it is confusing everyone who expects to see motors.
First thing I'd do is to change the arm blocks in Begin to be Motor Opens and Motor stores. Next change the Teleop arm blocks to Motor Set Output. These are on the Actuators palette, top left.
Also look at the Diagnostics tab of the driver station to see if errors are being reported. Handling unwired errors has a high CPU overhead. If you know how to fix the errors, do so, otherwise post them on the forum.
Greg McKaskle
