Go to Post Well, John V-Neun still has a little bit of hair. Maybe it'll be an astroturf field? - Amanda Morrison [more]
Unread 17-02-2011, 19:32
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: How to decide whether go left or right when the robot is at Y (bifurcate)
Random # generator... If it is under a certain #, go left, else go right. Simple as that. If you wrote your code correctly you should be fine.
