Go to Post The FIRST program is different. It has a different purpose. It isn't superficial, it's results are long term and lasting. I hope that FIRST is still on message. - JohnBoucher [more]
Unread 17-02-2011, 18:54
jackdawg's Avatar
jackdawg jackdawg is offline
AKA: Wyatt Cerilli
FRC #1307
jackdawg is an unknown quantity at this point
line sensing code
i have been looking at the default line sensor code and i cant seem to make heads or tails of it. has anyone written it from scratch? is it difficult to figure out??
also what do people think about it? is it like the vision tracking of previous years (not very helpful and a pain to get to work)?
my thought is that a much simpler autonomous would be easier. (ex. go forward, deploy arm, place tube on rack)
thanks in advance
-Wyatt C FIRST Team 1307
Unread 17-02-2011, 19:49
GunfighterJ's Avatar
GunfighterJ GunfighterJ is offline
AKA: Joseph
FRC #2450 (RaiderBots)
GunfighterJ is an unknown quantity at this point
Re: line sensing code
It's quite easy. If you know how to wire it up to the digital side car then you can just open 3 digital inputs and get teh value of them in boolean format. After that you can use case structures or use "boolean to (0,1)" to tell the drive motors to go left, right, or stop.
There are 10 types of people in this world. Those that understand binary, and those that don't.
Unread 17-02-2011, 23:13
National Instruments provides a very helpful Line Following Tutorial that explains its operation.
Unread 17-02-2011, 23:26
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
The default line sensor code essentially determines how to run the bot every some amount of seconds. That is either by goin forward full force, or turning and goin sideways
I'd suggest using a truth table, as the guide on NI suggest
Only problem is tat it makes the bot zigzag a lot over the line
Unread 18-02-2011, 09:42
Triapod Triapod is offline
Triapod is an unknown quantity at this point
Go to FRC Mastery. There is a breakdown of the code.
