Go to Post I feel like I need to rinse out my brain with drain cleaner - dlavery [more]
Unread 17-02-2011, 20:29
Exernie Exernie is offline
FRC #3080
Exernie is an unknown quantity at this point
Exclamation Code Problem :s
what we are trying to do in our code is have a 4 wheel drive on one joystick and then another joystick that moves a crane up and down on the y axis and turn it 360 degrees on the x axis. the problem is, i can't seem to get it all to work. I can get the wheels to work fine, and the crane to lift up and turn. but when i put the two together, nothing wors. idk what the problem is
Unread 17-02-2011, 20:38
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Re: Code Problem :s
Please post your code.
Also, check your wiring.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 17-02-2011, 20:41
FRC #3080
Re: Code Problem :s
our begin
teleop
Unread 17-02-2011, 21:37
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Code Problem :s
There may be a problem with your wiring, but you should not use Arcade Drive for things besides your Drive Train. Please see this post for information on how to correct this: http://www.chiefdelphi.com/forums/sh...3&postcount=14
This is the 2nd time today I've seen teams use a RobotDrive function for something not dealing with a drive-train, and I've never seen this before. Any ideas why?
