Go to Post This only gets awkward when the girl knows more digits of pi than you do... - Walter Deitzler [more]
Unread 17-02-2011, 20:34
Nahum Nahum is offline
FRC #2543 (TitanBOT)
Nahum is an unknown quantity at this point
Removing Modules from cRIO
is this allowed?
I've looked for something in the rules but it doesnt seem to say much on it,
Rule <R55> seems to be the one that might get it, but im not sure if removing the module is considered "dissasembling"
(we are trying to mount our cRIO vertically using the screws at the side, but with the screws the Pneumatics module would not fit, we arent using pneumatics so we think it should be fined, but we want to be sure.)
Unread 17-02-2011, 20:41
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Removing Modules from cRIO
The minimum legal number of modules is 2, an analog in slot 1 and a digital in slot 4. The additional analog, digital and 2 solenoid modules only need to be installed if you need them.
Unread 17-02-2011, 20:57
thank you very much, is there a source for this information just to be sure?
Unread 17-02-2011, 21:10
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
<R52-b> requires the digital module in Slot 4 and <R61> requires the analog in slot one. There are no other rules that require modules to be installed therefore they are optional.
Unread 18-02-2011, 12:49
bensherman's Avatar
bensherman bensherman is offline
AKA: Ben Sherman
FRC #1676 (The Pascack Pi-oneers)
Team Role: Electrical
bensherman is a glorious beacon of lightbensherman is a glorious beacon of lightbensherman is a glorious beacon of lightbensherman is a glorious beacon of lightbensherman is a glorious beacon of light
The analog breakout jumpered on the two leftmost pins (towards the end of the board and the center pin) is required for battery voltage to be transmitted to the driver's station AND FMS. The breakout must be installed on a NI 9201 module in slot 1.
2011 NJ Regional #1 seed, winner
2011 Virginia Regional winner
2010 New Jersey Regional Winner
2010 Virginia Regional Winner (15-0 )
2010 Curie Finalists
Editor - alltechdaily.com
