Go to Post If it's not on fire, it's a software problem. - Matt Leese [more]
Unread 17-02-2011, 02:18
tagayoff's Avatar
tagayoff tagayoff is offline
FRC #3512
tagayoff is a jewel in the roughtagayoff is a jewel in the roughtagayoff is a jewel in the roughtagayoff is a jewel in the rough
Problem with LabView Update 3.2 #2
We installed LabView update 3.2 and when we downloaded our code which was working with 3.0 the digital side car did not put out any pwm signals??? The rest of the digital side car worked. We had DIO inputs from the line sensors and compressor switch working. And the relay outputs to the compressor worked as well. Only the PWM signals were not functioning. I didn't have a scope to check the pwm signals but the Jaguars and the victors didn't see any. Is this a problem with the FPGA crio load?? Help.
Thanks
Tom
Unread 17-02-2011, 06:24
rclothier rclothier is offline
Coach, Team 1723
AKA: Russell Clothier
FRC #1723 (The FIRST Bots of Independence, "The FBI")
rclothier is on a distinguished road
Re: Problem with LabView Update 3.2 #2
I just installed LabView Update 3.2 #2, and now LabView won't run at all. When I try to launch it, it says "Unable to open resource files." This is a horrible time to have no LabView! Suggestions anyone?
Unread 17-02-2011, 14:27
Alex Redman's Avatar
Alex Redman Alex Redman is offline
Zombots Lead Programmer
AKA: Alexander Redman
FRC #3013 (Zombots)
Alex Redman is an unknown quantity at this point
when did first give out the 3.2 update?
Last i got, it was 3.1.
Unread 17-02-2011, 14:47
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
It looks like it was released yesterday.
Unread 17-02-2011, 15:00
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
The FPGA did not change with 3.2, only NetConsole changed.
Doug Norman
Unread 17-02-2011, 15:02
That seems to mean you tried to run the update from within the .zip file.
Uncompress everything and run it again.
Unread 17-02-2011, 15:03
We've heard of this happening when Windows decides to update in the middle of your FRC install. Usually running the FRC update again fixes it. I'm curious how you run the FRC update. Do you unzip it to a folder, and then run the installer?
Doug Norman
Unread 17-02-2011, 22:23
dotbran dotbran is offline
AKA: Brandon Olsen
FRC #3219 (TREAD)
dotbran is on a distinguished road
I'm having this same problem and the same error message pops up every time I try to install the 3.2 update. I also cannot roll back to 3.1
Unread 18-02-2011, 09:40
Exactly how are you installing it?
Doug Norman
Unread 18-02-2011, 13:06
AKA: Brandon Olsen
FRC #3219 (TREAD)
By extracting everything from the .zip archive and running Autorun.
I'll just reinstall LabVIEW.
Unread 18-02-2011, 13:40
tagayoff's Avatar
FRC #3512
Thanks
Tom
Problem wasn't with the update at all. Learned about the DriveSafteyUpDate.VI. The TeleOp.VI wasn't running fast enough.
Unread 18-02-2011, 15:03
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Exclamation Re: Problem with LabView Update 3.2 #2
How did you solve the problem?
Unread 18-02-2011, 17:29
windtakers windtakers is offline
AKA: Blake Dansfield
FRC #3620 (Average Joes)
windtakers is an unknown quantity at this point
I'm sorry to say this, but we had the same problem and the way we fixed it is to reinstall labview. also remember to extract the update before running it.
Unread 18-02-2011, 19:40
tagayoff's Avatar
FRC #3512
We had to remove some code that was measuring a Potentiometer in a while loop inside the teleop.vi The code wasn't running fast enough for the WPI_RobotDriveSafetyUpdate.vi to get the update signal that resets it so it disables all PWM signals. Then the Jag's/Victors see no control and disable their oututs. I think...
Unread 19-02-2011, 00:27
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Can you post your code? In general, it is a bad practice to put while loops in the Teleop.vi for the reason you mentioned. When we implement sensors we normally put these in a "Sensors" While Loop in Periodic Tasks, with about a 20-40 ms wait.
