Need help - pwm
We are having a problem with pwm - the dashboard shows that pwm ports (on slot 4) has output while the joystick are moving, but jaguar lights keep yellow, and motor does not work as a result.
Any suggestion on troubleshooting? |
Re: Need help - pwm
2 Ideas
1) Check to make sure that the pwm cables are plugged in the correct way, there easy to get backwards. 2) Try replacing the pwn cables. I know that last year at a regional one of our motors wasn't working and replacing the cable fixed the problem Hope this helps. |
Re: Need help - pwm
All status lights on the Digital sidecar are a bright and glowing green?
The Dashboard shows you what your code is ordering, but nothing downstream from that point. |
Re: Need help - pwm
is the motor blinking yellow or is it solid yellow?
blinking= loss of connection solid = good |
