Go to Post They could release an update saying they were going to give every team free puppies and kittens, and many teams would vehemently complain this change was too late to budget dry kibbles into their budget. - artdutra04 [more]
Unread 14-02-2011, 18:21
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
CAN Error -44087
We are trying to get our robot wired using only CAN, but unfortunately, we cannot seem to get can to work on one jaguar that controls our lift. We can drive using CAN, but cannot seem to get that jaguar using the open CAN jaguar vi to work. Sporadically, the set motor vi returns a error -44087. Any Ideas?
Unread 15-02-2011, 20:55
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
Re: CAN Error -44087
We are having the exact same problem, would really like some help with this.
Edit: Appearantly this problem can be caused by a bad terminator or the speed of the loop that sends instruction to CAN.
FRC 1732 (Hilltoppers): Mentor
FRC 2338 (Gear It Forward): Mentor/Alumnus
FRC 4096 (CTRL-Z): Mentor
Unread 17-02-2011, 22:49
beth_hadley beth_hadley is offline
FRC #0548
beth_hadley is an unknown quantity at this point
We're having similar problems with CAN. We get "Error Code 44087: NetComm_CAN_Receive.vi:8" errors nearly every 5 seconds on our driver station output window. Our motors drive fine, but there is a tremendous amount of lag (nearly 1/4 of a second). We've tried adjusting the run time of the update loop, but nothing has worked. Interestingly, the autonomous does not lag at all. Any thoughts would be appreciated!
Unread 18-02-2011, 12:01
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
http://www.chiefdelphi.com/forums/sh...ad.php?t=91102
